idle speed screw = a/c off idle screw
u've jz made me speechless....
si fu.. how about nissan sunny E11 engine punya stock carbie screw? my car running wif a bit white smoke n dense gas smell..
FYI i just changed the air filter but my rpm decreased below 500.. if turn on the air cond then will be fine..
if i off air cond + on head lamp.. car stop...
so u mean white smoke doesnt related to the carbie problem? b4 changing the air filter everything fine... it just normal stock air filter.
could be the valve seal rosak as well.white smoke??... piston ring gone??.. need overhaul??...
if piston ring KO, does it mean static compression is lower than usual??... does this translate to lower idle rpm??..
sifoo sifoo help guide noobie here...![]()
how to tuned weber DGAV 32/36? and how is the layout? tq
jeng jeng jeng...
http://img481.imageshack.us/img481/1751/dsc07293rb1.jpg
1) yes.... 4g15 n 4g13 using the same carb....
2) jeng jeng jeng...
http://img112.imageshack.us/img112/2594/screwsqr2.jpg
3) screw in means clockwise... similar to water pipe... wanna close the tap (lean mixture), u turn clockwise....
4) the workshop usually tune my carb and ignition timing only charge me 5bucks... other workshop i dunno... but shouldnt be expensive....
my skyline is now 12 years old but its still a damm fine car.....happy new year to all skyliners
