Mod to GTi's ARB system
ganfh
Hello all sifus! Just wanna know what is to be done/bought if i wish to change satria's front anti-roll bar system to a GTi's arb system? Thx!:adore:
i think u need to get the ARB set.
the ARB, the "satay stick" with the bushing., and the holder to body with bushing.
not very sure about front proton setup.
does urs got the "satay stick"?
usually the bush already come with the satay.
You'll need GTI or aftermarket absorbers also.
The GTI's ARB is mounted on the absorbers while the normal satria ones are mounted on the lower arm.
Sifu has spoken :adore: GTi ones are mounted on the absorbers. Evo 1-3 ARB will fit in GTi but not GSR or normal satria as it is mounted on the lower arm. Even after you have the ARB, you'll need the stab link to connect your ARB to your absorbers.
u can improve ur handling via changing ur satay bush to more harder PU material on the stock ARB system.
Wow, thanks alot all sifus! Yup i only know GTi arb is mount on the absorbers instead but i have no idea on other items i need.
So the list is:
1) Absobers with arb mount/flange
2) Stab link
3) ARB from evo 1-3 (any other aftermarket ones which is thicker?)
4) Satay bush?
5)?
What about other bushes? Can use back ori satria front arb buses? U bush....? abit blurr on those hehe
Thx!
So the list is:
2) Stab link
4) Satay bush?
5)?
Thx!
evo 1 arb is the same with GSR.. onli E2 & E3 have arb mounted to the absorber..
Oh, thx bro tajulsans for correction...
So the list is:
2) Stab link
3) ARB from evo 2/3 (any other aftermarket ones which is thicker?)
4) Satay bush?
5)?
I think satay bush = stab link (Correct me if Im wrong). Anyway, if ur sourcing for good aftermarket ARB, u can go for Whitelines. Few of our GTi members are using Whitelines ARB and it works like charm.
Hehe, ok thanks bro Termizi!
Updated list for all who wish to do this conversion as well:
So the list is:
2) Stab link (aka satay bush)
4)?
5)?
Bro, where can i find whiteline products? Whats the best combination of thickness for front + rear arb? Thx!
Combination Im not really sure. Never used that before as its kinda pricey for me,but its worth every penny u spend if u go for Whitelines.
http://www.pentagon.com.my/
Or you can directly PM chris2000 for more info.
Mizi do u have pic of the ARB...dun have any idea what is the ARB...anyway is GTi suspension system same as 1.6 satria suspension system?
oem absobers.. KYB should cost less than 200 a piece. bought mine for 130. long time ago.
Stab link should cost RM 50 below for taiwans.. slightly more for OEM proton.
Ori Evo's are mucho expensive. The difference is.. which one will last longer. Has one taiwanese one.. the whole thing broke at the hinge and totally dropped off while i was connering..
ARB.. thickest would be those UR abrs.. 20mm i think. No idea how much.. Ori is.. 16 mm.. i think
Bush.. super pro .. less than RM 100, 2 piece. I have if u want. PM me
Thats all you need... U may want to add in sgti spring to go with your absorbers. They are slightly harder.
If mounted properly.. then nice and slightly hard. If not.. you will be hearing lots of "bunyi tikus" very soft .. but audible.. makes u think like u got small BOV.
While you are on it.. perhaps u may want to consider changing your crossmember to evo's.
oic now i know ARB stand for anti roll bar huhuhu
