nah , most of u guys got it wrong, if u hit an uneven surface , doesnt mean it has to give way , first do know how camber works , do u all have first hand in setting camber ? or u guys speaking from other ppls saying :)
camber is adjusted via a bolt and nut which is holding your suspension shocks , here is the picture
i adjust camber on my own , and there will no reason to give way unless you run a "cheap nut and bolt" , "nut and bolt which is loose"
Actually, those ppls are not wrong at all as most of the stock cars are come with non-adjusted camber. And it might happened on old car due to wear and tear problem.
