BOT (Bolt On Turbo)
Dear Ahren,
What do you mean unpredicted problems ?
How was your setup ? what parts did you use ?
Dear Firebird,
My car still running fine. Until now only some minor problems like power window spoil, absorber got sound and thermostat & water pump problem. I think these are due to car old already. hahahaha
Basically, PS Powersport product until now still ok. I also added Max REV cut from PS.
Dear Lovemaker,
I think wastegate lowest is 0.3 bar. There are 0.5 bar also which same as what i am using now. Your Kelisa must be very powerful since you need 0.8 bar.
dragger racing and mal shah alam.. 4k plus..parts maybe all gsr parts n custom manifold..
Bot spec (booting @.5 bar):
-hks blowoff
-TDO4L
-stendet gsr intercooler
-gsr injector
-stendet 4g92p manifold and pistons
-gsr air flow sensor
-sard feul regulator
same spec with me but im using gsr piston , evo3 i/c and boosting at 0.8bar
but is auto tranny.. lol
maybe 1 day we can TT together..
Guys i upgraded mine BOT :) from 4G91 BOT to 4G92
Now the engine construction is under progess with :
4G92 1.6 Mivec Block
Toyota 8.9:1 Supercharged Low Compression Piston
1.5 Metal Gasket
1.8 GSR TD04 Twin fin turbine
1.8 GSR 390 CC injector and air flow
1.8 GSR Fuel Pump
1.8 GSR Intake Manifold
1.8 N/A Head and Cam
1.8 GSR Throttle Body
1.8 GSR ECU support with SAFC
expected boost 1.3 bar
previosly running on 4G91 BOT with standard piston boost at 0.6 bar no problem at all :)
1.5 Metal Gasket
1.8 GSR Fuel Pump
bro.. why use 1.6 block??? why dun u use g93 block??
a monster in progress!
guys. do u agree if we organize a BOT Party? all invited, (BOT owners off course)!!! .. if anyone agreed. i will make a topic for the BOT Party.. how does it sounds?
btw, mine honda prelude bb1, H22A DOHC VTEC TURBO!
anything call/sms/3G - 012-3555144 Bear , Shah Alam
total cost bro....
1.5 Metal Gasket
1.8 GSR Fuel Pump
bot party and gang the streets ? haha..
anytime man..but dun race race la.. :P
[Guys i upgraded mine BOT :) from 4G91 BOT to 4G92
1.5 Metal Gasket
1.8 GSR Fuel Pump
ahgy: BOT Party! minum minum n makan makan only! no race.. hehehe .. show offs .. pssshhhh pshhhhhh pshhhhh..
btw mine is AUTO .. so nice 2 drive. manual suxx.. change gear,clutch, traffic jams.. hahaha :P
Hi, can anybody introduce me some workshops in Damansara area which are good in BOT? Better familiar with Honda if possible lah, hahaha.
okok...juz install the emanage n tune the car
manage 2 hit 178hp
but one thing i notice is...the air fuel ratio shows very rich condition...even when idling...it shows a 10!
he said dat its due to narrow band...but this doesnt happen when im using safc...plz help!
TT can be done if u're at "Bandaraya Kuala Terengganu" area ;)
I got 1 unit gsr ecu but can't install it into my 4g92p. my foreman said the stock wiring not compatible.. did u change ur stock wiring.?
by the way mate, ur boosting @.8bar.. so brani ha.. ;)
1.5 Metal Gasket
1.8 GSR Fuel Pump
hei bro, isit u the one that i meet last time with angah and remy at taman pinggiran putra ??? you drive wira bot blue color rite ??? if yes, im waja bot with you that night :biggrin:
