- Joined
- Feb 2, 2006
- Messages
- 545
- Points
- 1,518
4g91,92 and 93'ers..pls do come in.."rojak planning"
*not sure whether this topic have been discussed*
Guys, after so many halfway canceled minor projects,finally able to collect some cash for some minor modi now..So just need some 2cent from u guys out there..
Current engine : 4g91
Mods : 4g92p or 4g93DOHC block and the internal
Power and Durability wise,Worth the drop in annot?
At the same time, i have doubts in certain areas which is
1) How does the compression ratio plays the part here. What should i go for since 4g91=9.5:1
4g92p/SOHC : 10.0:1
4g92DOHC : 11.0:1
4g93DOHC : 10.5:1
2) relationg to question1, the higher the compression is, the better it is right? correct me if im wrong. So if im gonna drop in the 4g92p(10.0:1) and wants the compression ratio be a lil higher (close to 10.5:1),should i add a thinner metal casket to make it a lil higher?
3) Comparing the piston stroke,
4g91 : 77.5mm
4g92 : 77.5mm
4g93 : 89.0mm
which is better?shorther stroke length or longer?
thanks for reading and commenting guys....app it..Good day!
4g92p/SOHC : 10.0:1
4g92DOHC : 11.0:1
4g93DOHC : 10.5:1
4g91 : 77.5mm
4g92 : 77.5mm
4g93 : 89.0mm
