Remember that accident where everybody said it was your fault and the only thing you did was drive straight? Unless you drove straight into a pole in which case you’re an idiot, I’m sure you were wishing you had a recording of the moment of the accident, everybody does.
Now you can have the recording, Brickhouse Security has came up with a rearview mirror camera recorder. Using a small camera mounted on the back of the rear view mirror, you can record everything happening in front of your car. The footage is displayed on a 2.5 inch LCD screen integrated into the face of the rear view mirror. It also includes handy playback controls in case you want to see an instant replay of your accident, track blast, top speed attempt, drift attempt or your stunt through traffic.
Here’s how it works: it needs to be plugged into your cigarette lighter, recording begins when the engine is started and ends when the engine is turned off. The footage is saved to an SD memory card, and can be played back on any computer or television. Now you can get all the evidence you need to prove that you’re not that bad of a driver, just don’t end up with evidence showing you caused a major accident.
