- Joined
- Jul 6, 2007
- Messages
- 87
- Points
- 1,508
Product: OBIT Piggyback ECU
Condition: Used, come with full harness for fuel,ignition and injectors.
Information: http://www.obitasia.com
Price: RM600
The Obit was designed to allow you to tune ANY engine. Signals are modified on maps found within the units and with windows software. Installation and tuning is simple and once installed the engine can be retuned by anyone with a laptop and the tuning software. An average installation consists of connecting 6 wires to the vehicles original wiring loom, changing the settings of the unit in the setup section of the tuning software and you are ready to retune the car. It has been found that an experienced installer can install an Obit unit within 30 minutes.
FEATURES & BENEFITS OF THE Obit - 1
All piggy-back units are reliant on the exiting ECU to provide the fuel and ignition to the engine. For this reason they are bound by the limitations of the existing ECU. Fuel is typically modified by changing the load sensor or lambda sensor signal. Ignition is done by delaying or advancing the crank angle sensors signal. The piggy-back unit tricks the ECU into thinking that it is running under different conditions thereby allowing for a different output.
Feature Benefit
- Throttle Sensor learning feature Fits to any throttle position
- RPM Calibration To suite your installation
- High RPM range Racing?
- Fuel map with 128 sites Smooth Programming
- Ignition Map with 128 sites Fine Ignition resolution
- Injection Map with 128 sites For extra (boost!) injection
- 0 - 10 volt analogue range Allows tuning of all models
- 6 Amp injector drive Handles 6 x 16 ohm injectors
- Various ignition outputs For the most stringent applications
- Selectable Trigger points To suit
- Programmable Cylinders It works on any amount of cylinders!
- Selectable polarity To Suite
- Can handle interlaced signal For 4 cylinders ignition output tuning
- Balanced Inputs Inverted Outputs
- Missing Tooth Signal For up to 2 teeth advance/retard
- Ignition output limit Limits max. advance and retard
- Fuel High low limit Prevents overdriving the ECU
- Small Size Fits Anywhere
- Low Battery Drain Simple Installation
- Self Checking Test Available For Extra Confidence
- Map Switchable While you drive
- All Inputs Protected No mishaps!
- Crystal Controlled For Stability
- Encapsulated For Moisture and Dust
- Easy Tuning Software DOS or WINDOWS
- Low Component Count High MTBF
- 10 MIPS computing To facilitate quick engine response
- Signal Conditioning To prevent miss trigger
- Engine profiles (library) Easy set up
- Lambda Signal Tuning Modification of Lambda Senor Readings
- Proportional Nitrous Control Less waste of power in nitrous injection
- Adjust Dwell Time For very basic standalone applications
- Rpm / Airflow / Analogue Defection / Temp Switch Point For cam switch and similar applications Test
RECOMMENDED TUNER:
- Drager Racing. Turbo Sang, K.L (0192636927)
- RS Impressive. Robin, K.L
- Joe (0167711444), Johor
*** Interested Pls Kindly sms/email me at 0126068802 , [email protected]
NO PM PLS, SELDOM CHECK PM.
Price: RM600
Feature Benefit
RECOMMENDED TUNER:
