Ecu Rechiped/Remapping
klotz_coxoc
Any Mitsubishi ecu that has an eprom can be remapped.
A Honda P28/P30/P72 ecu can be done. Additional function such as launch control, full throttle air cond cut off, shift light can be added. If interested, please pm me. Tq
lot of mitsu ecu can be remap..honda yes...bullshit that all lair
I'm confused.. What are you referring to? Can you be more specific?
ignore that dude and carry on with your business,
yuhanisa: pls dont condem ppl's thread, if u had bad experience remapping at ur Ah Beng shop just keep it to yourself. thnks.
BUMP BUMP!
klotz bro.... 6A12TT ecu can add launch control function?? and aircond cut when full
throttle??? Kindly pm me ya location and how much it cost...
Thank you..
izzit true that mitsu ecu has letter 'M' on ending serial ecu cannot remap...
only letter 'E' can remap?
can pm me the price pls..
Yes it is true.. M stands for embedded, E stands for eprom. Pricing depends on the setup you require.
i've got an eg9 ecu i am not sure what the code is. can it be reflashed? please pm me details such as how you will be retuning my ecu and stuff like that with price too. thanks.
Hi, for an EG9 ecu, *best if you can reconfirm the code number, it can be rechipped, meaning replacing the original eprom data with a tuned data. A chip holder will be soldered to your ecu, where by you can at anytime change to another chip in an instance. For tuning purposes, you're opt to do either road tuning@wideband or dynorun tuning(this you have to pay at the dyno centre)
On the road tuning i will use a wideband sensor and do a few runs to get ur afr rite. same goes to dyno tuning.. except ur car will be static on the dyno wheel but this could cost you a few hundred for the dyno run itself. Pricing depends on the setup you need. What I can offer you is that, afr map optimised, ignition, rev cut increase, launch control, shiftlite (illuminate at certain preset rpm by triggering the engine chk lamp), full throttle air cond cut off, and adjustment to the vtech trigger.
I'm located around ampang area. You can visit www.racetune1.com or www.racetune1.com/forum
Thank you..
Hi sorry for the late reply.. Am sorry but a 6A12 TT ecu is not an epromed ecu. There for I cannot do anything to the ecu.. You can either install emanage to manipulate your ecu.
Bro klotz,
Mitsu GSR 7377 ECU
MD307377
E2T38386
4310 E
How much for remapping?
can u PM me the detail futures of this remaping? Tq
Hi, I'm sorry but it is not possible for me to do subaru gc8 at the momment but I'll keep you posted on updates..
Bro, do u do performance reflash for new Lancer GT with 4B11 NA? Wanna squeeze the best from this NA car la.
:biggrin: my ecu from cd6 h22a (auto) was repair 2008. now i change to manual gearbox but computer box is original.. can it rechip?? cod number f90 37820-pof-902 cy-eh1353a.. cost, please pm me..:itsme:
localStorage.removeItem('xenFHideSidebar'); } }); }); $(document).ready(function () { 'use strict'; $('#gece-modu').on('click', function (e) { e.preventDefault(); $(document.documentElement).toggleClass('gece-modu'); if ($(document.documentElement).hasClass('gece-modu')) { localStorage.setItem('xenFDarkMode', true); $("meta[name='theme-color']").attr("content","#090909"); } else { localStorage.removeItem('xenFDarkMode'); $("meta[name='theme-color']").attr("content","#202020"); } }); }); $(document).ready(function () { 'use strict'; var aktifYukseklik, currentScrollTop = 0, header = $('#xenF-header'); $(window).scroll(function () { var scrollYukseklik = $(window).scrollTop(); var headerYukseklik = header.height(); currentScrollTop = scrollYukseklik; if (aktifYukseklik < currentScrollTop && scrollYukseklik > headerYukseklik + headerYukseklik) { header.addClass('slideUp'); } else if (aktifYukseklik > currentScrollTop && !(scrollYukseklik <= headerYukseklik)) { header.removeClass('slideUp'); } aktifYukseklik = currentScrollTop; }); }); $(window).scroll(function(){ if ($(this).scrollTop() > 50) { $('#xenF-header').addClass('headerShadow'); } else { $('#xenF-header').removeClass('headerShadow'); } });
