Siemens VS MMC
yes can test many time but after 100km\h no more power only 1st 2nd and 3rd gear.... i using 14 light weight rim...
12oY,
r u using 4g93 quad throttle?nice engine pic u got..
I think his 4G15 is fitted with 1.6 pistons...... otherwise 8.5 seconds is really kind of impossible....But I am unsure, coz 4G15 twin weber can kick ass......:biggrin:
that not my engine hahah... no la i fitted oversize piston la.... just 0 - 100 only power other suck lo....4g15 engine cant go much more unless heavy mod la... but really can 8.5sec lo
i wan say is the most important is the clutch set no much slip so more the power is fully transmit to gear box compare to ori cluth set...then engine running stock is for save fuel so the power not fully utilise.. is depend how we understand the engine and how engine work and how to tweek the engine for performance and how for economical all we need is to undestand so we can tune to better porformance ... yas i admit 4g15 engin cant go much power band but abit sure can...4g15is not a powerful engine but for learning sure is a good basic engine.... chear i still on learning
then why vios stock auto can done 9.68 sec can but my 4g15 manual cant leh? just fast them 1 sec cause i test run with my fen vios 0 - 100 just can fast him half car only but after 100km/h then me kena tapau kau kau by vios...when test run 400m....here the prove vios can run 9.68 sec http://www.youtube.com/watch?v=BqGFNB1G9-Q&feature=related ....
actualy me is kind of looser also cause vios auto then mine is manual .. if the vios is manual sure can do more way better than 9.68sec maybe 7 or 8 sec.....hahaha tell u what i have drive vios manual version.....planning to get 1... no belive go to show room ask toyota salesman about vios J model is basic 14'' steel rim manual model ..power unbeliveble .... price cheaper than E or S model... :thefinger:
Dun compare with VIOS la bro....
Vios vs 4g15
1) Dohc vs SOhc
2) 16v vs 12v
3) high compression vs low compression
4) VVt vs apa pun talak tech
5) light weight vs heavy weight
6) 110hp 140Nm vs 80hp 100Nm
above the list already kill 4g15 stock to stock lo..hahaha
but for my 4g15..consider heavy mod liao did 8.3sec hahaha....only 0-100 other then that...every car can smoke kaw me ..hahahah
Vios vs 4g15
1) Dohc vs SOhc
2) 16v vs 12v
that y i say vios is auto me is manual........ the car lost is power at the transmision itself.....soch is mid range power doch is high range power.... vvt is for cam profiling auto adjust for performance at low and high engine speed and fuel economical.... .. and i would like to say vios is low compression than 4g15 is high compression...4g15 ori is 80hp but after twek abit then ok abit lo ... but still kena tapau by many car lo hahahahahaha boring dy ,, plan to get vios....
VIos compression ratio is 10.5:1
4g15 compression ratio only 9.2:1
this is why you see Vios pickup is to light..
BOT your 4g15 Siemens VDO, I believe can tapao stock VIOS already. :driver:
indeed nice topic here. so my simen GTI syuck at 170km/h any solution can unleash the power of 4g93p??
why not change da whole wiring and ecu to mitsu 93p?
oh yeah, 1.5 mmc ecu..can use 93p tb and/or perdana tb??
sifoo... i thought 4g15, 4g92p (wira sohc) and 4g63 sohc (perdana sei) throttle body are interchangable??... plug and play ISC rite??...
i need all the otais n sifus to help me to identify my ecu..actually, i dont know whether my gti is running on siemens or mitsu ecu..i had seen my ecu..but i dont remember how it looks like..so my question, my air flow sensor indicates a mitsubishi sticker on it..on the sticker is a serial number or what, PW550450..does it means that my gti is running on mits 0450 ecu??plzz sifus..
Bump: i need all the otais n sifus to help me to identify my ecu..actually, i dont know whether my gti is running on siemens or mitsu ecu..i had seen my ecu..but i dont remember how it looks like..so my question, my air flow sensor indicates a mitsubishi sticker on it..on the sticker is a serial number or what, PW550450..does it means that my gti is running on mits 0450 ecu??plzz sifus..
difference between svdo and mmc ecu...
http://img02.picoodle.com/img/img02/3/4/16/catacombs/f_WiraEcum_986ab2f.jpg
yup tat is how a SVDO Ecu looks like.............for wira is right underneath the glove compartment area..................
attachment.php
from the picture..this gti engine running on MMC or SIEMENS ecu?
Bump:
attachment.php
