Garrett(new Ori) A/r 70 In Box
takazz3
Garrett (GT40) (new Ori) A/r 70(GT40) In Box
GARRETT
A/R70 GT40 TURBINE(NEW ORI) -
HYBRID / BIG TURBINE
CAN GENERATED MORE THAN 1+++HP
VISIT GARRETT.COM
OILCOOLED ONLY
IMPORTED FROM JAPAN
ITEM NEVER USE
WITH BOX
RM 3999
URGENT . COD
IF WANT TO INSTALL ADD ANOTHER RM499.
CAN USE BACK UR OLD BASE. FOR EXAMPLE ..
FRONT HOUSING AND BACK USING AR-70 TURBINE BUT BACK HOUSING UR OLD HOUSING WITH OUT USING BANANA ( CAN SPOOL MORE COS UR BACK HOUSING IS MORE SMALLER THAN FRONT HOUSING-
013 275 3666
THIS IS ACTUAL PICTGURE OF THIS ORI TURBINE
journal bearing gt40?not ball bearing? no water cooled? whats the spec for turbine housing.. AR?
what is the compressor inducer and exducer size? what size is the turbine housing?
SPEC ARE : turbine inducer.62mm/exducer .68mm/84trim/.82ar
compresso inducer .62mm/exducer.82mm/57tri/.70ar
Can support 1000hp
congratulations nice item.....this call turbo bro.....bump 4 u
:adore::adore::adore::adore:
