Can the VVT ligth connected to our meter? i'm using white meter (Auto) come with menu & power LED.
this nothing got to do with the meter...
it's a separate unit by itself...direct connect to ECU...
haha ....wa lau .....a lot ppl poisoning of MR CHIN item edi ....must give me special price edi ...cuz i help u promise oso ......yek yek yek
3000rpm to 6500rpm .....oooic .....
mr chin ....are u using the velocity stack ?
if using LED...
+ve connect to B+ (batt)
-ve connect to VVT
both on ECU terminal...
the left one is not recommended...the right one is fine...
ok I'm little bit confuse.. hehe means that:
1. VVT on Light off ( not recommended) ?
which mean..u will have ur vvt light ON all the time...but when VVT kick on..ur VVT light will go off.......
you dont want this right???
you want when the vvt kick in..the light will on....![]()
hehehehhe..it is up to you...
read it and digest it....then you will understand urself..instead of waiting people to tell it to you........
within this range...3000rpm - 6500rpm...
