what is the maximum boost for the er34gtt/rb25det neo that i can play safe with??? is 1 bar ok? anyone out there please help me with some advice and tips.thank you....
1bar occasionally still ok ... but nothing more than that...1 bar shld be the max max max ... advise is to do 0.9 bar max actually
Anything more than 1 Bar is a NO NO ... Why I know ... Twice, I overbooast to over 1 ... twice the stock turbo blew up ... the rear fins melted .... once even damage the engine .... painful and expensive experience for me :(
Go aftermarket turbo if you want to boost more than 1 bar with the right mods done up like fuel pump, ECU and injectors. Now it is easier to get Garrett turbo cheap compare to those days plus they can be repaired locally too.
I am looking for new or used weather strip i.e inner door mould on the body and outer door frame, front and rear windscreen and inner rubber on quarter window.
All the half cuts coming are without rubber strips. How...
hie all,well i have a question here..how do i actually determine that a trubo is healthy and its in good condition..?? i was told that once a turbo is not working well,white coloured smoke will be emitted from ur car...
