HID Bulk
kojai
malacca/jb
HID Bulb
Hi Guys..
How to make our ori HID bulb evolution more brighter...
Pls advice:banghead:
Kojai, our ori HID 4K , change to ralliart bulb 6K brighter enuff... if u want to upgrade higher also can...just change the bulb no need to upgrade the ballast..
If still not bright enuff, install PIAA foglights!!! :burnout:
upgrade to 6000k or higher will kena stop by jpj?
Azizi...
Where to find? how much the cost...
That y your bulb so bright kan...
JPJ...me no problem
Azizi...
JPJ...me no problem
Kojai, mine is ori... but as u know the bulb has life span, bcome dim after years... i suggest try to change new one but still 4K bulb (Philip)..
localStorage.removeItem('xenFHideSidebar'); } }); }); $(document).ready(function () { 'use strict'; $('#gece-modu').on('click', function (e) { e.preventDefault(); $(document.documentElement).toggleClass('gece-modu'); if ($(document.documentElement).hasClass('gece-modu')) { localStorage.setItem('xenFDarkMode', true); $("meta[name='theme-color']").attr("content","#090909"); } else { localStorage.removeItem('xenFDarkMode'); $("meta[name='theme-color']").attr("content","#202020"); } }); }); $(document).ready(function () { 'use strict'; var aktifYukseklik, currentScrollTop = 0, header = $('#xenF-header'); $(window).scroll(function () { var scrollYukseklik = $(window).scrollTop(); var headerYukseklik = header.height(); currentScrollTop = scrollYukseklik; if (aktifYukseklik < currentScrollTop && scrollYukseklik > headerYukseklik + headerYukseklik) { header.addClass('slideUp'); } else if (aktifYukseklik > currentScrollTop && !(scrollYukseklik <= headerYukseklik)) { header.removeClass('slideUp'); } aktifYukseklik = currentScrollTop; }); }); $(window).scroll(function(){ if ($(this).scrollTop() > 50) { $('#xenF-header').addClass('headerShadow'); } else { $('#xenF-header').removeClass('headerShadow'); } });
