Yes it might be true but not necessary..... diskbrake can hold up to at least 650 brake horse power....but i'm not sure about Drum. AS you can see...mostly Sports car are equip with front n back diskbrake. Do more research than u'll know which one is better...... diskbrake actually has more brake power than drum and much more realiable.after further discussion with some people... i found out that drum brakes are more reliable then the disc brakes especially if it is on the rear wheel.... more braking power...
how about the ABS brake system....?
it will give function to rear disc brake...?
or no, cox orginal just in front only..?
may SE using the brand advance - testor 3 star....for me is makan....may be u can try it...RM 90.00 - front , behind - around 140....
oh really?? ok.... cos my friend got 1 bad experience using disk brakes... he changed from drum to disk and apparently like no brake at all... mayb setting problem kua..
juz wanna tumpang thread, i got 1 set of AE101 rear disc wanna let go, together with dual layer master brake pump, for details please pm me, or contact me @ 0125300063, ivan, thanks ya~!
i have change just my SEG ( Original 4AFE - Auto ) rear disc brake only .
...not change the brake pump to dual layer
so braking system have been improve...
but if compare with my SE ( full half cut 16V 4AGE - Manual ) , my SE is better .....very makan
so i have some question .....
1) Is it my SE brake pump is dual layer ?
2) Have any difference between Auto & Manual ?
3) AE92 , AE100 & AE111 levin brake pump dual layer are same ?
4) How much for the dual layer brake pump ?
5) Just change the existing single layer change to dual layer , how about the piping for brake ?
just use back all....?
As you may know, JNC’s Art Director (the one responsible for our new design and layout) owns just one mode...
