Coil Spring Buffer(Damper) for Various Car Models
jojo9984
5,000 RPM
Guys...I am selling coil spring buffer(damper) for various car models..
Benefits of using coil spring buffer:-
Helps restore spring tension
Provides life to sagging coil spring
Reduces noise and vibration from suspension component
Improve stopping capability
Fast installation and obvious result
Suitable for all types of vehicles
Selling Price:RM60 per box(1 pair) or RM110 for 2 boxes(2 pairs)
NOW RM130 WITH INSTALLATION
Contact No: 012 565 8656
For installation service:
PIT STOP SERVICE CENTER
ENTRANCE C, LEVEL B1,
SUNWAY PYRAMID, SELANGOR.
Call me for more details:biggrin:
Buffer Sizez for Various Car Models
For those car models, that are not listed above, kindly arrange with your mechanic to measure the spring in order to get the suitable buffer sizes.
Refer below on how to measure:-
Installation guide:
1. Jack up your car. For safety, make sure it's stable enough.
2. Prepare solution by mixing dish washer detergent + water in a small bucket.
3. Deep the buffer into the solution and install them as the photo (slot coil into the bottom part of the buffer first)
4. Release the jack slowly and make sure all the coil spring fall into the buffer nicely.
5. Drive and go over few bumps or try to take some cornering to let the spring compressed into the buffer nicely
Sizes
1. Model A: Spring Clearance (47mm)/ Spring Thickness (13mm)/
Spring diameter (173mm)
2. Model B: Spring Clearance (35mm)/ Spring Thickness (13mm)/
Spring diameter (160mm)
3. Model C: Spring Clearance (27mm)/ Spring Thickness (10mm)/
Spring diameter (131mm)
4. Model D: Spring Clearance (23mm)/ Spring Thickness (10mm)/
Spring diameter (113mm)
5. Model E: Spring Clearance (15mm)/ Spring Thickness (9mm)/ Spring
diameter (112mm)
6. Model F: Spring Clearance (12mm)/ Spring Thickness (15mm)/
Spring diameter (120mm)
http://www.zerotohundred.com/newforums/search.php?searchid=2226714
bro, please pm me the best price for Civic ES1.
Btw, is this rubber or silikon.
Thanks.
Is this the same item as the other two forumers deal with ?? Hw much best price for 1.5 Satria stock abs with tanabe spring ?
pm replied..it's different from the other 2 forumers..
bro...its difrent from others brand..silicon or rubber..can post or not..
for gen2 1.6
bro, pm me the best price for proton waja..can courier or not?cost?tq bro.
Is it this item can fix to any model cars?
How about installation?
different car has different sizes..but i have all sizes..installation at any workshop or tyre shop..
can post or not?pm me best price for toyota LE
