But u can always switch back to petrol if u need power right?
Hi SB3,
Yes. Anytime you want to switch, just press the button and it go!
My car setting at 0.5 second delay for changing of fuel to prevent jerking when one fuel cut in, the other out.
If you want power for NGV, it can be done too, by installing a device called TAP (Timing Advance Processor) with additional cost about Rm 300, depending on car system. i didn't use because lazy to retune my car as it takes another few hours to get perfect (tune, test drive,.. tune, test drive... untill satisfied).
i think the nissan guys need to check manually. Well if they r able to detect using consult II let me know the code, i may be able to let u know which component is causing the problem.
yo mic, your B&M DAMD brother finally emerges!!
