- Joined
- Feb 19, 2006
- Messages
- 1,383
- Points
- 1,638
who is jinkl ? can ask him join this topic ka ??
He is zth taiko...ekekeke :P
if skytec want to use at 4g91 why use vr4 flywheel?use gsr 1.8 right?:hmmmm:why don't try to use ori d.shaft first as it's also 2wd...nothing to lose if you try'...to bro skytech....i have 1 g/b mirage 2wd n 1 g/b mirage 4wd fulllock with LSD....I USE my fulllock gearbox with lsd into my saga la sekarang....mirage g/b have a good ratio .....banyak budak cari to kacuk theare gearbox ....banyak budak take the finale drive only kasi kacuk sama dia punya g/b....for your info i pernah pakai engine 1.6t with 2wd g/b perang with wira e3...that car kena tapau sebiji setengah with my car....mirage g/b is made for good picup not for topspeed....if u 1 to install into saga or iswara u kena ``tempah`` driveshaf ....rm700 for1 side...saya sudah 3 kali putus drive shaf bila saya pakai g/b mirage itu bukan driveshaf sambung bro....for your safty u should coustem la bro...4 clutch u can fit with vr4 flyweel or cluth....u can`not use evo123 clutch not same la bro....clutch pump u can use wira clutch pump with minor mod i use or ready in my saga now.....if u have a prob with 4g61t u can msg or call me bro i can help u....tq![]()
if skytec want to use at 4g91 why use vr4 flywheel?use gsr 1.8 right?:hmmmm:why don't try to use ori d.shaft first as it's also 2wd...nothing to lose if you try'...![]()
YA , g00_61t bro , what i wish to noe is , now i need to find the clutch set , include the pedal , clutch pump componet fullset ( current gearbox using cable type) . I heard wira type can be use rite ?
And another is , my iswara driveshaft cv joint is confirm not match with the gearbox joint rite ? what kind of car driveshaft joint i need ? so tat only i can mod on my driveshaft .
TQ TQ .
), MME Sepang J's Racing review...
