as far as i know only VR te37 can fit 4 pot for 15inch rim.
that why ppl still looking at this rim,champion ma.
No, you will need a spacer for the 15" SSR.
Minimum 15mm. You might need longer wheel studs as well.
don la put spacer,later your car vibrating la.
let go your ssr and buy te37! what for using 4 pot brake but using spacer?ure drowngrading your stability bro.
TE 37 also u need offset 32+. Not all TE 37 can fit. Spacer can use but must be japanese type. Not the local spacer. Then the stud u need to custom made 3". Very expensive.
why not just get the Wilwood mini 4 for Jazz..???
wilwood quite expensive wor...
btw, how u know im drive jazz?! lolz
bcoz u ask me for the Topfuel b4... hehehe,,,.....
wilwood is bout rm3k plus for used & rm4k plus for new set ma... with pad, & rotor edy....
or u just searching for Spoon used 1 for rm2k plus, u can using the calipers with ur stock rotor... ask for ur Type-C, sure can clear...
Here are some Evo X that i snap back from Super import nights... :-Chua :stupid::ciao:
