REV Performance Garage Sales !!
andysky5
At Rev Performance, we sells all types of Car Performance Parts from All over the World (Japan, USA, England, Australia,Taiwan and etc.)
- All Parts are New and Genuine, unless stated otherwise.
- We ourselves are car modification enthusiast and have many Years or experience, so we will try to provide good recommendation to you.
- We provide Warranty for our Products...so you have no worries if anything goes wrong !!
- If the Item you are looking for is Not listed, please Pm / Call / Sms me and i'll check it out for you ( As we are not able to list the Hundreds of parts we Sell due to time constraint. TQ....Cheers
:biggrin:
Engine Performance parts :
Kelford Racing Camshaft - HOT !!
BPi Velocity Stack USA - HOT!!
WORKS Enginnering Products
Works Performance Oil Filter
Fuel Bank Evo II - HOT !!
http://www.zerotohundred.com/newforums/engine-and-performance/307090-ngk-iridium-ix-spark-plug.html
Denso Iridium Power Spark Plug
http://www.zerotohundred.com/newforums/engine-and-performance/305020-nrg-racing-meters.html
High Performance Hydraulic Lifter for 4g91/92/93 - NEW !!
RALLIART Final Drive 4.8 for 4G9X - HOT !!
EPS Power Charger
http://www.zerotohundred.com/newforums/engine-and-performance/305995-original-sard-fuel-regulator.html
http://www.zerotohundred.com/newforums/engine-and-performance/244692-fuel-regulator-high-quality.html#post3131405 - Hot
Works Engineering Ball Bearing Air Charger
Super Ignite RSD
Arospeed Performance Plug Cable
http://www.zerotohundred.com/newforums/engine-and-performance/286625-original-tial-wastgate-38mm-and-44mm.html#post3635092
Tial style Wastegate
http://www.zerotohundred.com/newforums/engine-and-performance/312641-tial-mvs-wastegate.html
Turbosmart Wastegates
Manual Boost Controller - Various Type
http://www.zerotohundred.com/newforums/engine-and-performance/240161-hks-super-sqv.html#post3085107
http://www.zerotohundred.com/newforums/engine-and-performance/289046-greddy-type-rs-blow-off-valve.html#post3666210 - New
Adjustable Fuel Regulator (OEM type)
http://www.zerotohundred.com/newforums/engine-and-performance/349996-skunk2-intake-manifold.html
Throttle Body 65/70/80mm
Super90 Billet Throttle Body - HOT !!
http://www.zerotohundred.com/newforums/engine-and-performance/350884-works-adjustable-cam-pulley-for-most-cars.html
http://www.zerotohundred.com/newforums/engine-and-performance/293313-p2r-adjustable-cam-pulley.html#post3718084
http://www.zerotohundred.com/newforums/engine-and-performance/209411-aluminized-thermal-cloth-for-sale.html#post2779699
Aluminium Pulley Kit
http://www.zerotohundred.com/newforums/engine-and-performance/246892-high-capacity-fuel-rail-kit.html#post3159660
Honda B16a/B18c Vtec Adjustable Cam Pulley
Block Guard for Honda B-series
http://www.zerotohundred.com/newforums/engine-and-performance/250888-firehill-exhaust-thermal-wrap.html#post3206738
http://www.zerotohundred.com/newforums/engine-and-performance/255231-oil-catch-tank-for-sale.html#post3259429 - New
Cusco Oil Catch Tank
Nissan SR20 Performance Parts
http://www.zerotohundred.com/newforums/engine-and-performance/257956-thermal-intake-manifold-gasket.html#post3292161
http://www.zerotohundred.com/newforums/engine-and-performance/258029-ngk-power-cable.html#post3292969
Bubble remover tank / Breather tank
http://www.zerotohundred.com/newforums/engine-and-performance/266165-magnetic-oil-sump-nut.html#post3387651
Skunk 2 Resevoir Cover
Engine Damper Kit
http://www.zerotohundred.com/newforums/engine-and-performance/297523-power-enterprise-timing-belt-2.html#post3894473
http://www.zerotohundred.com/newforums/engine-and-performance/271319-walbro-255-lph-fuel-pump.html#post3448607
http://www.zerotohundred.com/newforums/engine-and-performance/301315-stainless-steel-turbo-manifold-for-gsr-4g93t-evo123.html#post3827166
http://www.zerotohundred.com/newforums/engine-and-performance/310730-performance-intake-manifold.html
http://www.zerotohundred.com/newforums/engine-and-performance/313210-tomei-camshafts-for-4g93-evo123-and-other-cars.html
http://www.zerotohundred.com/newforums/engine-and-performance/332048-piper-racing-camshafts.html#post4238110 - New
http://www.zerotohundred.com/newforums/engine-and-performance/322114-hot-bits-ss-extractors-for-various-cars.html#post4112457 - HOT !!
Spoon Reservoir Cover - Nice !!
http://www.zerotohundred.com/newforums/engine-and-performance/336829-transparent-timing-belt-cover.html#post4299049
http://www.zerotohundred.com/newforums/engine-and-performance/325211-cometic-metal-head-gasket-for-various-cars.html#post4158295
Turbo Charger
EXEDY Racing Clutch
http://www.zerotohundred.com/newforums/engine-and-performance/328350-triniti-racing-clutch.html#post4201311 - NEW
Competition Racing Clutch Kit USA - HOT !!
T-Bolt Hose Clamps
Greddy & Cusco Performance Engine Oil
KAAZ Transmission Gear Oil
http://www.zerotohundred.com/newforums/engine-and-performance/367199-engine-mounting-full-rubber.html#post1063437982 - NEW
**Fuel Injector Cleaning Service
* Dynamic Engine Balancing Service - NEW
JUN Racing Camshaft
Matspeed Performance Camshaft
Jasma Performance Camshaft
RACE-TECH Smooth Shift Bushing
Racing Oil Pump for 4g9x Engine
Dynatek ARC-2 Ignition Booster
Cooling Mist Water Methanol Injection Kit
ACL / King Engine Bearing
CP/ Wiseco/ Supertech (Forged Pistons)
Toto, Izumi, Toyota Piston for 4g9x and Evo123 - NEW !!!
Duratech Con-rod (Connecting Rods)
ARP Head Studs
Engine Oil Cap
Breather Filter
HKS & VP octane booster & engine cleaner
Hi-Tech Stainless Steel Extrator for Honda B series & Mitsubishi 4g9x
Super Single Racing Clutch for Mitsubishi GSR CK Turbo
WORKS Alloy Aluminium TT Crank Pulley
KAAZ LSD Limited Slip Differential - HOT
Exhaust Cutout Valve - Electric
- HOT !!
Intake System & Filter
http://www.zerotohundred.com/newforums/engine-and-performance/365764-k-and-n-drop-in-and-open-pod-filter-offer.html#post1063422225
Apexi Power Intake
http://www.zerotohundred.com/newforums/engine-and-performance/262624-open-pod-air-filter-intake-kit.html#post3344234
WORKS Engineering Drop in Filter
Project S Super Stainless Drop in Filter
http://www.zerotohundred.com/newforums/engine-and-performance/245966-hks-super-power-flow-reloaded.html#post3147438
Simota Aero Form Intake System - HOT !!
http://www.zerotohundred.com/newforums/engine-and-performance/274804-hks-replacement-filter-element-dry-3-layer.html#post3490645
Stainless Steel Filter
Real Carbon Filter
UTR Super Flow Performance Drop in Filter - hot
http://www.zerotohundred.com/newforums/engine-and-performance/249157-simota-twister-for-honda-eg-ek.html#post3186142
Pipercross cold air Intake duct
http://www.zerotohundred.com/newforums/engine-and-performance/250109-cool-air-intake-kit.html#post3197487
http://www.zerotohundred.com/newforums/engine-and-performance/250908-intake-air-ram-kit.html#post3206969 - New
Aluminium Piping
Mugen Air Box
Electronics
http://www.zerotohundred.com/newforums/interior-and-cockpit/304330-nrg-meters.html - NEW !!
http://www.zerotohundred.com/newforums/engine-and-performance/310716-e-drive-throttle-controller.html - NEW
http://www.zerotohundred.com/newforums/interior-and-cockpit/255885-sports-meter-defi-style.html#post3266125 - New
Pivot Shift Lamps - New
http://www.zerotohundred.com/newforums/engine-and-performance/299990-apexi-afc-neo.html#post3807555
http://www.zerotohundred.com/newforums/engine-and-performance/292447-greddy-emanage-blue.html
M7 EM-com ECU - NEW
Haltech 500/1000/Pro ECU - HOT !!!
Pivot Speed Meter V
http://www.zerotohundred.com/newforums/engine-and-performance/283404-pivot-raizin.html#post3596724
http://www.zerotohundred.com/newforums/interior-and-cockpit/266932-apexi-el2-boost-meter.html#post3396272
Shift Lamp
V-Manage Ignition Amplifier
http://www.zerotohundred.com/newforums/interior-and-cockpit/264060-apexi-pen-timer.html - New
Turbo Timer
Innovate Wideband Air/Fuel Ratio Gauge
http://www.zerotohundred.com/newforums/interior-and-cockpit/283063-engine-start-button-2.html - Hot
Ignition Earth
http://www.zerotohundred.com/newforums/engine-and-performance/246446-grounding-cable-kit.html#post3153704
Direct Ignition Panel
http://www.zerotohundred.com/newforums/interior-and-cockpit/250951-volt-meter.html
http://www.zerotohundred.com/newforums/engine-and-performance/254233-electric-fan-temperature-controller.html#post3246899
HKS Style Grounding Cable Kit - Hot
Electronic Boost Controller
Silicone hoses :
http://www.zerotohundred.com/newforums/engine-and-performance/246291-silicone-radiator-hose-kit.html - New
Samco Silicone hose
http://www.zerotohundred.com/newforums/engine-and-performance/220354-samco-silicone-vacuum-hose-for-sale.html#post2880078
http://www.zerotohundred.com/newforums/engine-and-performance/230846-silicone-elbow-and-reducer-for-sale.html
HKS Vacuum hose
Cooling parts :
http://www.zerotohundred.com/newforums/engine-and-performance/243511-dei-performance-coolant-additive.html#post3119285 - Hot
http://www.zerotohundred.com/newforums/engine-and-performance/191029-performance-aluminium-radiators-for-sale.html
Wira, Satria, Putra, Evo and Civic eg/ek Performance Radiator
http://www.zerotohundred.com/newforums/engine-and-performance/298926-honda-eg-ek-aluminium-radiator.html
http://www.zerotohundred.com/newforums/engine-and-performance/358430-aluminium-radiator-cooling-plate-air-diversion-plate.html#post1063330946 - NEW !!
Engine Oil Cooler Kit - New
Engine Oil Cooler
http://www.zerotohundred.com/newforums/engine-and-performance/260890-intercooler-hks-style.html#post3326087
ARC Intercooler
Automatic Transmission Cooler Kit
http://www.zerotohundred.com/newforums/engine-and-performance/283058-electric-fan-performance.html#post3592057
http://www.zerotohundred.com/newforums/engine-and-performance/346817-low-temp-sports-thermostat.html#post4418837 - New
Synergy Radiator
ARC Aluminium for Proton EVO/GSR and Honda Civic
Braking system :
PRO-RS Braided brake hose
High Performance Brake Pads
Brembo Brake Fluid
Sports Brake Rotor
Brembo Brake Disc Rotor - NEW
VTTR Brake Kits
Skunk2 rear lower arm for Honda Civic EG/EK
Interior / Exterior and Body parts :
Ganador Side Mirror
ViewRec HD Smart Portable CAR DVR - NEW !!
http://www.zerotohundred.com/newforums/interior-and-cockpit/289016-works-teflon-gear-knob.html#post3665700 - New
http://www.zerotohundred.com/newforums/interior-and-cockpit/267605-bride-low-max-seat.html#post3407804
Philips crystal vision
Real Carbon Plate
D1 Bonnet Pin
Sparco bonnet pin
Sparco Rear Pin / Hook
Aerodynamic Number Plate Holder - New
http://www.zerotohundred.com/newforums/engine-and-performance/310938-gear-short-shifter.html
Bonnet Damper
Suspension parts :
HWL Full Adjustable Suspension - NEW !!
HWL Adjustable Suspension - HOT !!
Adjustable Suspension Kit For Proton Cars
Ohlins Performance Suspension _ BEST !!
Ultra Racing Chassis Stabilizer Bar
BC Racing Adjustable Suspension - HOT !!
Aluminium Lightweight Rear Lower Arm for Proton - NEW !!!
Vogtland Sports Spring Germany
Tein Sports Spring Japan
GAB Suspension
Rear Lower Arm bar
Suspension kits for Nissan RWD cars
Honda Adjustable Suspension kit
Rear Suspension arm for Proton Wira, Putra and Satria - New
Rigid Collar - RACETECH Chassis Alignment Kit - HOT
Aluminum Rear Lower arm for Proton - NEW
Room bar
Adjustable Front / Rear Camber & Toe Kits
SuperPro Polyurethane Bushing
HARDRACE Adjustable Suspension ARM
Spring for adjustable Suspension - NEW
Car Audio :
Focal and Zapco products
Others :
TPi Forged Aluminium Wheel Nuts - HOT !!!
TPi Wheel Lock Nuts to Prevent Rim Theft - HOT
Alloy wheel nuts
Sports Wheel Nuts - New
Fire Extinguisher - Safety First
Oil Temp/ Pressure Sensor & Cooler Adaptor
Water Temperature Sensor Hose Adaptor
http://www.zerotohundred.com/newforums/all-other-stuff/377155-samco-silicone-hose-key-chain.html#post1063546957 - CooL :D
[MAP] Sunway, Petaling Jaya, Selangor, malaysia[/MAP]
Address :
No.7, Jalan PJS11/24,
Bandar Sunway,
46150 Petaling Jaya, Selangor.
Note: Rev Performance (1st floor above Matspeed), same row as Teck Ming Silverstone tires near N1 racing.
Operating Hours : Monday to Saturday ( 10.30am - 6pm )
Please pm or sms for COD at Rev Performance, Bandar Sunway or Postage by GD Express ( postage will be charged ).
Pls Whatapps or Call me : 017-3526055 (andy)
Bank In Details :
Bank : Maybank
Account no : 112231051159
Name : Low Chun Hung
https://www.facebook.com/pages/Rev-Performance-Auto/194149357289701
Please Click for : **** REV Performance Website ****
More products coming soon !! TQ :burnout:
Bro i want silicone hose:
1 ASR elbow 45 degree size 2"
1 ASR elbow 90 degree size 2"
4 ASR straight 2"
3 meter samco vacum hose 4mm
Pm me best price with courier to ipoh.
tq.
4 ASR straight 2"
tq.
Okay bro, pls check your pm....Tq
Hi...can u pls locate ur shop?...thanks
