1.6ers Owners (Mitsi/Proton)
4g92p reporting in..nak tny skit sape2 yang ada xperience...aku plan nak tuka cable plug..ape jenis yg bagus utk enjin ni eh??tq..
sohc or dohc? u can try ngk power plug cable.....good thing:listen:
mine also 4g92P C98 Model and recently i just change my gBox from auto to manual (4g93 SOCH G/B) , the pickup quite better and the FC reduce not so bad.....now iam very happy with my ride hehheheh not giving trouble like before. So then my plan to give the engine have good breathe one ( doin top Overhaul ).:biggrin:
so ur doing PNP la.good luck to u mkhairul.hope ur achieve what u aim for.:driver:
i using the 1.5mm coz wanna install the mivec piston together....but after all gaw dim d, still cant find the piston, so hv to using it 1st loh....i dunno, after done the twin cam project, whole car power totally difference....:burnout:
hoo.. like that ok la, for future upgrade.
i got situation here, the car got slight jerk and not consistance, it's occur when got load (meaning drive on the road) but if idle n just rev like there is no effect at all....izzit spark leakage from spark plug cabel? or maybe distributer? my car feel very slugish now... even try push to higher rpm, the meter rpm always bumpy it self n jerking occur... :banghead::banghead:
hv been replace spark plug, fuel filter, and fuel pump...
update from previous prob...
hv been replaced distributer, a lot diff in smooth revving, but stil got disturbance at high rpm (just slightly) which the rpm meter will bounce a little bit itself... usually at 6000rpm and really obvious when cornering while full throttle....
Dear 4G92 owners....
Our rpm cut (rev limiter)is at about 6750...
Ever wished it could be alittle higher like 7500 so that can tarik a little bit more to feel
the power?
Let me do it for you...
PM for detail if interested...
the power?
Free ke bro?hehe..kidding..btw tell us how u doing..:listen:
have to check it out 1st bro.....coz many thing can happen....
