hi all taiko... have anyone here got change their car bushing b4??? usually change back to original type or aftermarket??? how to know its time to change??
u call Steven n Julian (KL TaiTai Kor) both of them had change to TRD bushes.... so far i didn heard them complaint........ only thing they said after change TRD bushes become 'ngan' just like continental car......
i need to know where i can get these headlights https://www.zerotohundred.com/forums/attachments/168208
You probably have to jack up your car to check whether the bush is hardened or cracks. I can say the steering feel tighter around corners but didnt hear any noticebale increase in noise. (I have mild hearing problem
). guess trd is the option i should go for... btw will the trd bush make noise when cross bump or uneven road???? our car front only got how many bush? i have asked original bush, as bro ryonan say they wont sell the bush only it comes with the arm... and for the lower arm got 2, is straight 1 is rm540 per pcs, if lower arm "L" shaped is rm390 per pcs which is pretty costly......
Im on TRD bush for my front lower arm (Total 3 pcs on each side. Part No. 48654-SE100, 48655-SE100 and 48655-SE100). I change them because my suspension was making alot of noise and it is a common problem that our worn lower arm bushes being the culprit. Cost me SGD 400+ to order them but in the end, it was my cucso antiroll bar bush causing all the trouble.You probably have to jack up your car to check whether the bush is hardened or cracks. I can say the steering feel tighter around corners but didnt hear any noticebale increase in noise. (I have mild hearing problem
You can go to TRD website for more info.
http://www.trdparts.jp/english/parts_bush-altezza.html
thanks for the info bro... as wat u saying that ur anti roll bar bush causing the trouble.. do u mind to tell me wat kind of sound or in wat situatuion it will causing the sound?? thanks....:proud:
Bro shawn55..u can forget about asking aycy to contact vision anymore..becos he wont anymore.
Becos u guys screw him alreadi....
prefer kl area...
