What problem is this? sound from front wheel.
bro i have this problem few days back....go to foreman..and found out that problem lies with the brake pad....need to add 2 metal plate..the ok already
you can try getting your car on a floor jack and free rev it till 80~100kmh. and see if can pin point the source of the sound. if it's not audiable, it might been coming from parts which takes up car's weight, bearing, drive-shaft, arms soso.
Hmm most of the symptoms just giving preliminaries method to check by your foreman.. Try to eliminate one by one starting with wheels.. do prior balancing and check the wheel bearing.. then comes to driveshafts, then steering rack, and lastly your engine.. there is no other shortcuts bro.. Only professional formen knows best.:biggrin:
i m having the same problems also.... got sound click click click when i turn slow corners like in a car park, straight line dont have...... changed drive shaft cv joints at both ends and stabiliser links already but sound still there....so frustrating...
