- Joined
- Mar 30, 2006
- Messages
- 429
- Points
- 1,518
actually im looking for something that can upgrade my car ignition. Looking for MSD but it is too expansive. Item below are item for boosting your engine Ignition system also.
Any member, sifu,taikoh using D1 spec product below? can these compare with MSD?
Give some reviews
D1 Spec VSD II
= Ignition System Boost:
Increases the original 12V to 15,8V.
= Increase the Horsepower and Torque:
Ignition system strengthening provides better electricity power.The exhauhttp://www.zerotohundred.com/newforums/newthread.php?do=newthread&f=15stion of electricity makes acceleration weak.It will give you totally brand new feeling.
= Decrease Carbon Dust Accumulation:
Strengthen the ignition system to burn the gasoline fully.It will not only decrease the carbon dust accumulation because of incomplete buring,but also lengthen the life of engine and exhaust system.
= Decrease Fuel Wasting effectively:
Burning effeciency becomes better and better after the ignition performance is promoted.Using every drop of gasoline effectively can decrease fuel wasting up to 20%.
D1 Spec 2008 VSD IV
@ Support up to 6 coils
@ More spark energy & power
@ Quickens throttle response
@ Improves idle & starting
@ Increases Economy
@ Superior Performance
@ Street,Drag,Race and Drift use!
Increases the original 12V to 15,8V.And comsumer can adjust the output from 15.8V ~ 18V depends on different needs and situations. This product has LED voltage display device, customers can easily see the condition of the VSD.
Provide enough electricity even under huge power consumption situation.Ignition becomes better and easier.
Ignition system strengthening provides better electricity power.The exhaustion of electricity makes acceleration weak.It will give you totally brand new feeling.
The significant difference between these 2 models is for VSD IV, this product can increase voltage to 18V. Consumer can adjust the output voltage from 15.8V to 18V depending on different needs and situations. Besides that, it has LED Voltage Display Device
Bump: this item can decrease fuel wasting up to 20%.
Menthanol water injection system can safe up to 30%
Plus NGV can safe up to 70%
my car can drive with water liao
my car can run with water liao
Give some reviews
D1 Spec VSD II
D1 Spec 2008 VSD IV
@ Increases Economy
