Rc real craft body shell drift car 4wd 1:10
All Other Stuff
Kashadalegends
Murah... murah.... pakej yang menarik.... sekiranya anda beli asing setiap
komponen yg terdapat dalam pakej ini anda perlu membelanjakan :
# Rc lightning + drift tyre rm480 (harga downtown)
# real craft body shell with braket light rm 250
# 1 set light 8 led full function rm150
# set drift tyres gred 'A' rm 90
Cuba kira berapa yg perlu d belanjakan.:smokin::smokin:
Lightning Casis With Pakej Craft Real Body With Light. :driver:
Feature:
Four wheel drive system with shaft drive
Fast Speed: 60km/hr (40 mile/hr)
Tamiya On-Road Racing Car look alike!
Equipped with high speed motor and bevel gear differential gear box
Transmission shaft enables the car steadier, light shock & fast speed while
running
High capacity 7.2V NI-CD rechargeable battery
Front /rear bumper provide good protection against accident impacts
Equipped with axletrees to reduce friction of the components and to run
smoother and faster
Front and read double wishBONUSe spension
Coil spring shock units
Sturdy ABS monocque frame
Sealed gearbox
Twin motor-driven 4WD system
Mid-dhip mounted battery
3-step speed controller included
Semi-assembled chassis
Powerful RC-540 motor
Built-in front and rear bevel gear differential
Double wishBONUSe arms with adjustable width
Oil filled dampers
Top quality chassis
Complete disc brake system for quick brake response
Pre-trimmed aggressive durable tires
Complete Kit, Ready to Run (Everything is included and 100% assembled)
Real craft Body with light
*Condition New Item many unit.
*Gred ‘A’ drift tyres
*Real Body with light all function.
*head light on
*tail light on
*break light on
*signal light on
*Chose body Skyline, Nissan 350z,
*RM60 for courier or self collect # :driver:
# area Keramat, Wangsa Maju, Ampang.
Harga RM 760
hp: 012-3802415 ( kasha )
call/sms only.
are u sure using twin motor and 3 step mechanical speed controller? and also have discbrake?
hehe... aku xde hal xspeaking... moderator yg bg law kena speaking...
anyway, check properly before u write down.. actually there are no 3 speed for esc. esc use variable speed. and this model i think not use mechanical speed controller but using esc.. and also, impossible EP unit have disc break.. only GP use disc break..
motor tu berapa turn? 23T? What chassis? TT01?
chasis like tamiya tt01. tapi china brand. barang tamiya bole masuk. motor aku x pasti coz standard, code motor sama mcm tamiya yang standard. Aku bangga dapat komen mcm ni x mcm cik_yat keje nak kondem org. mcm bagus, baca spect pun x paham. xkan brg tamiya bole dapat murah mcm nie. dah comfirm nie barang klon. tamiya seketul tt01 yang basic pun paling murah rm 700.++. kat shop tamiya pun rm 899.00. dah aku jual pakej. nak pakej mcm aku nie harga bawah rm400 tokey babi pun lingkup. saja buat aku bengang.:mad:
relek bro..biasa la mcm tu..baru angkat sebijik mcm ni..
layan bleh adjust speed dgn sensitivity kat remote..
kalo dpt tayar drift lg cun..brg mmg best tp battery kene bagus la kawan..tp harga dah cun..:thefinger: aku angkat pn lebih kurang mcm tu gak..so support member2..gud luck bro:wavey:
aku mmg xbgs bro.. tp aku nk cr yg bgs... explain kat aku system disc brake keta ko.. aku pki tamiya braking xbgs lgsg sbb xde discbrake.. kalu dpt nk gak aku sumbat dlm keta aku.. anyway, keta ni totally different with TT01..
ko nak tau sistem break kete aku... disc depan ventilated twin port brembo. disc belakang single port brembo. sport rim advance rg 17 tyre yokohama advan. absober tien high low/soft hard. itu yang cengkam...
hahaahhaa..... ini rc la.... bukan kete kancil nak buh disc break. aduh.... kete rc mingak pun xde break disc. aduh.... lemau aku ngan mamat nie. aku duk belek kete rc nie... x jumpa servo break disc clipper pun x jumpe. yg ader spacer wheel ala..ala... breakdisc. nanti aku minta brembo cipta break disc untuk rc. heheheehe... ko tuka la receiver yg ader sistem break. org main rc mana guna break sgt wat panas ecs bole la. kalo nak rasa ada breaks abs tuka remote bran hl remote brand china la. sama ngan set yg aku jual nie. ko pandang tamiya je... lupa lak!
Bump:
tq bro.... caya sama lu! :biggrin:
releks la bro.. lu xpsl angin nape lak.. aku pki brand china gak.. utk race je aku pki tamiya..
ko gak yg ckp keta rc ni ada disc brake for quick brake respond.. tu yg aku minta ko explain.. tp kalu korang main rc xguna brake takut esc panas nape nk ade brake yg bagus lak?? setahu aku brake yg paling penting utk semua kenderaan walaupun rc.. imagine dat u drive 60km/h (ur speed spec) n suddenly ur child across ur car n u car have no brake!!
ko xcaye keta rc minyak ade disc brake, tgk pic bwh ni..
aku bkn nk cari psl.. tapi share info.. xkisah la brape pun ko nk jual.. tp info kena la btul..
anyway, hl remote kira canggih sbb ada abs system n bleh set fast abs or slow but respond very slow..
aku copy paste jer ape yg tertulis.... so ko tanyalah sape yg reka. ko nak kongsi info ape? aku dah ckp aku hanya manjual bukan mengkaji. dalam feature cakap tamiya look like, what pe aku nk tipu. tp chasis alloy dgn tamiya hampir sama. lubang skru pun sama cuma gear berbeza. lightning brands gear kasar bunyi pun x sedap. ko buka lah website ebay china semua tulis mcm tu, kat manual book pun sama. aku pun x pakai brand nie. aku pakai HSP nak aku jual brand nie mahal belum tentu laku. so aku jual la brand yg market ada dekat downtown. aku pun sibuk bisness xde masa sgt dengan rc nie ada order aku hantar guna DHL. nie just part time bisness dgn member. member pun ada kedai hobby.. dari aku kejar untung x seberapa nie tu pun ada kata mahal lagi baik aku kejar tender kerajaan.
ko pun tau remote hl nie punya function. makne nyer ko pun guna model yg sama kan. ada 2 brands yg guna remote nie. lightning & gtr2 model electric car lah. rc aku x penah aku set break... track drift dkt One Utama damansara xde jalan yg bole speed. rc aku pun aku dah lock lsd guna break lg melilau. control speed dah cukup. lain lah main sprints kene guna break. :driver: guna motor d1 t11 pun bole lg control. tgh drift nak break membuang lah kete ni aku cite kete aku. setakat free kan speed bole lah. nanti aku nak oder d-box cheatting drift. kalo nak lah. tapi x gentle, lg pun masuk tournament xleh pakai sistem d-box. ok la bro. selamat hari raya. ko tanya aku lebih2 pun mcm aku bole jawab. main pun jarang. ada sape nak beli aku jual... nak minta kurang tgk jenis body yg cust pilih. yg aku tau kat plaza angsana model lightning dekat rm500 x masuk tayar drift. model ventex drift rm 600. betul x? budak johor bg tau aku. bateri 4500 nimh rm 250. aku bole jual rm200. :smokin:
bro before sellin sumthin make sure u know wat ur sellin.. dun simply copy and paste the spec... and say owh i just copy and paste bout the info true or not i dun know. in the spec say come with disk brake and cik yat is asking... and u story bout urs using advand rg with tyre yoko?? tein hilo sohard hahaha jus my 2cent no offence.. btw im using drum brake, jrd with tyre bridgestone,
gud luck and free bump.
hahahahahaha.... shut up!!!
bro.. 4500mah nimh wut brand? never seen lah.. only heard 4200 and 4600..
bdk jb yg kaye je yg beli kat angsana.. nk murah cr kat area psr borong and smart..
