check your power steering hose, maybe there are some leaking.. for the moment try check and if necessary add power steering liquid first..
hye viostar...izit that sound like "bergesel"??...my car's steering sound like that..huhuh..still wonder why...:rolleyes:
I think sound like what u said! but only during turning time.
How huh? how to solve? or the power steering soon wanna "Kong" ka?
Any advise ne?
Does it happen when you turn almost full lock? aka U-turns?, I use to have a knocking sound..mechanic said its was my drive-shaft, however it cured itself several days later.
...what a nice car..hehehe..in my case,even i turn just a bit,it come that sound...as i know, if drive shaft problem, it sound "ktak-ktak" when make a U turn, right??..
wah excel....cured itself??...what a nice car..hehehe..in my case,even i turn just a bit,it come that sound...as i know, if drive shaft problem, it sound "ktak-ktak" when make a U turn, right??..
...acctually my car have a idling problem( TB kong!!), when the RPM just 800-900..the sound came out, but when i set the RPM around 1000++,...the sound gone....my car is green colour, and i call it "the mystery green machine"..
maybe 9 years car will come this problem...hehhe..i'm using 14" inch rim only...but the steering abit heavier then other wira (i have try before..). ..when highspeed, best woooo...when side parking, like auntie.....acctually my car have a idling problem( TB kong!!), when the RPM just 800-900..the sound came out, but when i set the RPM around 1000++,...the sound gone....my car is green colour, and i call it "the mystery green machine"..
i not yet install the VS......acctually i install a piece of "toyota" thing..i donno what to call but my mechanic say it a "vacum controller"..but in not that FICD..it can set the amount of air...you know la.,when TB kong,on the AC,the RPM will drop...after this modification, abit better la...for the RPM,not really consistant,sometime ok(1000RPM)..sometime lower then 800RPM...when lower then 800RPM,the sound came out...for now,the sound gone for a while..hehehe![]()
Hey friend,
How much you got the "vacum controller" installed?
Yup, I read from forum some of the ZTH member did installed it. Some will good feedback some are not! So I am thinking to get one as well.
The said go for "FICD" Fast Idle Control Device.... But are your's is the FICD??????
For this few days, the weird sound gone... I might need to see further it might come back neh.
I replaced the ori plug cable with "Pro Ralley High Performance Plug Cable" added with Bosch Super4 spark plug..... Can feel that the car gainning some power compared to previous with ori spark plug & plug cable.
Might wanna to try out the Pivot Voltage Stabilizer with grounding as well.
Any advise or suggestion?![]()
My 3 year old Wira SE also got sound very soft "tak tak tak" sound when turning from a standstill especially if the ground not perfectly flat
Mechanic said not the drive-shaft, tested doing U-turn million of times until almost puke but no sound came out
He said maybe the stabilizer suspension related :hmmmm:
