The best way is to put the whole set from halfcut if you can affort it.
the disc you bought have a same diameter and thickness with your rear brake set?
hy to all "RE MASTER" in this forums.. salam to all muslim... i have a question,and hope u all can help... im plaining to buy and install a set of 4pcs bosch coil pack(which normaly poeple use with microtech ecu)at...
Hi Guys, Is me again...
I Might need help about my axle,
I realize that when i changing my tranmission oil.
Then i found out the axle was leaking some kind of oil.
I called Wing Hin they fax me a list of the axle...
Out of curiousity, I came across the discussion regarding ceramic coatings for downpipes and exhaust parts. This triggered a memory flashback where I once saw a random photograph of a ceramic coated rotor housing...
