get a set of EK9 98 spec ori used for rm800 better la...
Yeah its true, but its kinda hard to find this bumper.
Furthermore if he really willing to spend up to 800 he should have gone for 99 spec instead ...
you already answered yourself with your question.sorry guys.... borrow this thread while we on the subject of 99spec.
FYI, it's been quite some time since i've converted from 96>>99... Getting a 99spec makeover really freshen the car's look. But I a bit fed up cuz there is a gap between the grille and bumper..(an quite a big gap actually)
BTW, I do understand bout poor fittings on aftermarket parts.... but all my parts are OEM new except (used ori) headlights and bonnet. And upon comparing Hikaru-san avatar in 99 forum, damn......
I do encounter a small fender-bender while in 96spec... I suspect my front frame the prime suspect for my situation..... So i hope any sifus can clarify this before i buy the damn frame. Thank you........![]()
what front frame?how much is a front frame for 99specs?? Anybody know??
err, the one that tie our headlamp, radiator to our chassis.... The one tat gt plat stating chasis no. and air-cond gas....:hmmmm::hmmmm: dunno how to explain.:sleep:
Radiator Support
Why would you wanna change that? You don't have to change that to do 99-00 conversion.
OK... This is my car's front pic.
Pic 1
-The headlamp and bumper is not flush... i.e. the headlight's is poking out
-The bumper and fender are not allign properly, funny cuz it seems tat the bumper will misalign itself after awhile.:stupid::stupid: Even though it's been screwed up properly.
https://www.zerotohundred.com/forums/attachments/179043
Pic 2
-Last time fender-bender on the driver side, so u can c tat there is a bigger gap between the grille and bumper ON the driver side....
Pic 3
-There's a gap between headlights and fender......
I hope this can clarify a little, thanks for ur info.....
Pic 1 is pointless coz all EK are fixed with the headlights slightly pop up from the bumper, about 5mm. Of course, if you don't like this raise 5mm you can make the headlights flushed with bumper by adjusting the headlights.
Pic 2 is not the grille having problem but in fact your bumper. Usually if you make sure the grille are nicely slot into the bumper, everything should be tight up with screws underneatlh. But if your bumper position is not right, then it will force the grille to pop out like what you have here. IF you check your driver bumper, you can see it's poping out. Why? Because your bumper support bracket is 96 and you probably didn't have the slot made properly, you can still move your bumper backwark a bit so the grille and bumper will minimized.
Pic 3 I don't see much gap between headlight and fender, but I see more gap between hood and headlights instead on both sides, I think you have raise your hood to high.
You definitely screw up the bumper position when you install bumper beam coz the bumper brackets below the headlights are adjustable which you can raise it up and down, or moving forward or backward. Defintely it wont fit right no matter 99-00 short brackets or 96-98 long brackets when you take it down, you have to adjust it back with numorous test fitting.1. Understood.....
2. Last weekend, while installing the FR bumper beam. I've screwed-up the grille and bumper. The bumper beam tat i bought, came wit bumper support bracket. I believe it's ek99 spec cuz the bumper beam is from yr99 and it's definately shorter than ej....:rolleyes:
you just have to twist the rubber adjuster on radiator support to lower it down.3. Will check wit my mudguard-lao bout the hood...
Thanks a lot, appreciate ur help...
bumper beam is the great thing to push the car infront....:proud::proud:
im going thru this shit atm, but its my own fault for using some taiwan parts HAHAHAHA fcuk =\![]()
