Hi guys,im new here...i would like to ask u guys where should i go if i have problem with my S15..the problem is all my sensor light on dashboard not appear before starting engine(sometimes happen sometimes OK)..this problem start after i got problem with my ignition coil..after checked,one of my ignition coil detected not working...so i changed one of my ignition coil and the problem at engine side seems OK(no jirking anymore)
,but the censor problem still on and off+my car always "mati" when i step on gear 1 to move
..usually when traffic jam or slow moving(air flow not consistent base on engine sounds)..i went to ae workshop and checked the computer condition there are two error code appeared: 1)mass air flow sensor 2)IGN signal primary..as u know ae most formerly known for its subaru specialist so here is there any recommended workshop around subang jaya or puchong for S15(reasonable labour rate)
?...other than links dyno tune please....peace~~~
fixing is to with std n upgrade is diff....:cheers:
