overhaul...?
splitduck
hi there i have a nissan cefiro 3.0 brougham 01' which suddenly died on me..
towed to tan chong and they said 1 of the hoses blew..causing water to enter my engine..and my radiator water is boiling...they are asking me to look for a new engine..
can anyone help...?
wat can be done other than getting a new engine...thanks.!!
Hi,
If water is entering the engine is might due to the top cylinder head is warped (bent). This usually happens when the engine gets too hot (usually due to insufficient cooling, in your case a leak). Skimming the cylinder head usually will solve the problem. The head gasket is also to be replaced.
Otherwise getting a secondhand cylinder head is all it takes, not getting a new engine.
Good luck.
rebuild? i did this on my ke before buying it! same block n no scratch on pink paper.
can anyone help...?
Tan Chong only know to crap only la... if u can put a trust on some experience mech... just let me know...
