- Joined
- Jul 27, 2008
- Messages
- 150
- Points
- 1,516
my choice is ca18 to fit gsr. can used the piston + conrod + bearing. no prob. during high boost. cc increase summore to the piston size 83mm make 4G93 to 1.9cc. nissan piston very strong than mitsu. 4agze piston also good but smaller than ca18. bigger its better he3.
Bump:
need to skim both side of conrod only. if want lower comp. ratio u can skim top of the piston up to 1mm if metal gasket 1.8mm not enough.
like my car ke................ha3
i agree! aftermarket stuff can take higher heat temp n beating, from less expension to higher melting point n weight!!
