ae111 meter to ae101 local dashboard
EDRA
anyone got picture of modification of meter panel dashboard to fit ae111 levin orange meter?
why not u fix ae111 dashboard as well..no need to rewiring.more accurate:hmmmm:
EDRA, mine transplanted the whole dashboard, easier that way.
just to share and gives u more ideas, pic here
local dash stripped, ready for ae111's dash.
ae111's dash tulang goes in.
installed the inner item first, then comes the ae111's dashboard top
finally installed back all follow-up items...
finally the result is this
thanks bro for ur pic but i dont like ae111 dashboard. prefer to use back ae101 local dashboard more beautiful and nice colour trim
blackend, actually i dont want to rewiring but just want to fix the ae111 meter to ae101 local dashboard. anyone do this before?
i saw before got one member install that. it is not fit at all
Bump:
i saw before got one member install that. i mean levin ae111.
corolla ae111 can be fitted in but need to modify
Fix Fx meter ...white based ...nicer .....kekekek :biggrin:...
Bump: Fix Fx meter ...white based ...nicer .....kekekek :biggrin:...
but i think the ae111 meter not suitable to your ae101 dashboard.the shape not same at all..another option,u can use back your original meter..However,my friend install this meter to his local ae111 dashboard because the shape and length almost same
paging scottwrx ...modify ae111 meter in ae101 dash....reply help some bro need help.....
yes true the shape not same but i think we can modify the cover meter ae101 local fix to ae111 meter shape. no one did it before? tomorrow i take picture for the different of shape between ae101 and ae111.
i think we can use fiber glass to reshape the cover meter ae101 to fix on meter ae111.
bro.. u mean ae111 levin meter or ae111 carib wagon meter?
if u wanna try diy, then i suggest u to combine levin meter frame with ur seg one, cut about 2.5 inches of the levin frame ( measure from the inside) and use hair dryer or what ever that reshape the frame to meet the inside of the seg meter frame, ae111 meter frame is smaller than ae101 frame, so need a heat to make the frame soft enough for reshape
dun do anything to the seg meter frame except for shaping it to fit the levin meter
then use screw or clip to make it stick, the gap use paint cement to make it smooth n paint ... then should be ok.. i helped my fren do it long time ago..
upload the pics from the front n side, i can draw for u where to cut n where to combine, hope this will help
of not juz use the fx meter or gt wagon white face meter, juz plug n play, but need to the wiring to suit the bt wiring ( levin meter got 3 socket, n fx or gt meter got 4 socket, get a wire man to do it) this is easier
scott, upload some picture to share share the cut of AE111 meter in local 101 dash, and the final output also lar. that day i forgot to take picture of your dashboard at the meter there also. :p
i m using carib meter lah.. i think bro edra wants to put ae111 levin meter to the ae101 seg dashboard woh.. bro edra, post the pics, i show u where to cut.. u can try try n see, but to fix the meter, use those hardware store steel bracket with hole one, bend to match the location.. can fix already mah...
wah....DIY king givin suggestion ady...:listen:
no king lah.... juz passionate of doing things by myself and customising... sharing only lah... anyone can do it one.. provided got time to think only.... hehe...
Bump:
juz for u bro..
see.. not perfect also, got a bit of gap..
juz plug n play-sort of.. juz need some sponge on the meter frame to make the mater stable only
[/IMG]
left side
right side
top side
i juz got some black thin sponge that ppl use to make cushion one, can cover the gap already... but no time to do.. this weekend with do it and sure can fit perfectly
thanks. so nobody modific ae111 orange levin meter to local ae100 dashboard yet? i will do modific first than i show u all lah. take time cikitlah but if anybody want to show u modification regarding this meter/dashboard fixing just put here. maybe many ppl want to see it.
