can put more? i thought if over fill it will flood from fill in hole :hmmmm:
so, a 3 litre engine apparent needs 4~5 liters of engine oil only huh?
Looks like i was cheated by the prev so-called "cefiro expert" mechanic. No wonder everytime i check the indicator, it always showed very high level, i thought i was me that dunno how to read.
But strange, not oil spill over even used it for more than 7000km...
Just for update, changed the spark plugs to ori NGK ones, costs a BOMB!! It was RM45/pc!! for 6 pcs it's RM270!! WOW!!!
The box came with Nissan logo on it and the label stated it's for A32 V6...
RM45 man!! can get a box of normal platinum with this one piece only...
Bump: Yesterday the engine produced some knocking feel during idling, or when the car just about to stop during braking. Since changed new plugs, so could it be some sensors that dirty or fault?
Scared of stopping at road side ler!!
because the platinum spark plug box was came with Nissan logo on it....bro may knw where you bought it....frm nissan SC?...as i knw,copper spark plug box tat come with nissan logo oso alrdy rm105 something frm nissan SC...
that logo sure costly :proud:
i bought from one of d seller here.
Engine knock usually occur during acceleration or under load, R u sure ur engine knock during idle and decelaration .its quite serious if it knocks during idle.so, a 3 litre engine apparent needs 4~5 liters of engine oil only huh?
The oil will not spill over if its overfilled but u will feel ur engine slightly heavier and probably that would result of the knocking sound . It could be due to the hidraulic lifters floating. If possible drain the oil to the coorect level .so, a 3 litre engine apparent needs 4~5 liters of engine oil only huh?
if engine oil are too much, your engine power will be less, and also when you accelerate ur exhaust will have white smoke this will kill ur Cat very fast.
Hi guys, what is the grade of engine oil suitable for 10 years cefiro? 20/50? The engine oil should be more thick since 10 years car already?
Bump:
Leaking or not? BTW how's ur manual g/box . how fast is ur 1/4 mile when using ur MT? Any problem so far?my engine is younger than my car![]()
I suggest u that just change ur car to nissan cefiro a31 Rb20det or just change the whole engine to H22A (Big V-Tec).. Not very good in A.T if we dont take care... M.T is good coz if we use to after 10years or 20years still no problem at all.. Trust me, u will never regret.. I'm using Nissan Cefiro A31 RB25Det> RB25DE(Turbo)(Manual).Hi all...
My Cefiro A32 30GV lately having some gearbox issues. Previously, when push the stick to D, gear will engage immediately but lately it wont. Sometimes it'll take 2~3 seconds to engage (move) and during engage, there's a loud "kong" sound from gearbox/engine.
I have learnt that whenever the engine is cold, the problem will be there. So, normally i push to 2, after engaged gear and moving for say 10m or so, then only switch back to D.
So.. sifus, does this mean that the gearbox is time for an overhaul? or is it some other minor problems or sensors that causing these problem?
Anyone done overhaul gearbox b4? How much is the cost? Will it be better if just get a used gearbox from the junk yard?
Opnions and feedback appreciated!!
1] From DEVICE A
input voltage: 4.75V to 5.25V
max input current: 0.1 mA
output voltage range: 0.50V to...
