Hi there, I got one piece 6speed ecu from Toyota Levin BZR. It also can be used in 5 speed BT. Best for spare for 6 speed BT or 5 speed can gain better respond in acceleration. The ECU # 89661-1A860 is for the C-160 6 speed equipped AE111 which are compatible with 5 speeds as well, but mated with 6 speed transmission outputs, it has premature rev cut points in 1st and 6th gear and slightly changed timing curves for a split second after lift throttle and re-application to ease and protect the 6 speed's synchronizer and reduce driveline lash. Speed cut at 8200RPM. Selling RM880nego. Interested please contact Kevin 0169688921. Location Kajang. Item still in my car. Perfect working condition.
Pic copied from other sources
http://memimage.cardomain.com/ride_images/1/3217/1261/8040630206_medium.jpg
