Satria NEO: Rim's pcd?
JaHaX
Fellas ...
im getting my satria neo very soon
just wanna know what is the rim's pcd?
anybody can help me
thanks :rolleyes:
wirajadian ... thanks bro, by the way, do u happen to know the oem rim's offset? ...
Dr. D ... oic, what the hell are u doing here? ... hehehe
bro jahax...so sorry i dunno la about neo`s orginal rims ofset....so sorry aarr....:banghead::banghead:
wahhh ... thanks bro
more or less 20mm difference ... heck, wonder my +25 offset rim will fit the arch or not? ...
depend on rim width & tyre profile also.. if let say rim width below 7jj with +25 and decent tyre profile should be ok..
thanks bro ... the rim's width is 6.5 and thinking of using 195 size tyre ... should be ok ... thanks again
It can fit but you must roll your fender. Definitely going to hit the fender arches.
But, well worth esp when your rim filling out the fender gap.
I am using 7jj with +27 on 195/55 series rubber, FYI.
klu x nak sangkut fender,cari yg offset dia 42 keatas..
klu kurang drp tu kompom sangkut..mcm sy pnya skang..
Not necessarily bro. You should take your car height as a factor too. Ride height too low & soft suspension would definitely rub your arches even with +42 offset. Before my current setup, i use a 6.5jj with +32 offset running on 195/55 series tires with lowering spring. The car sits nicely without having to roll my arches.
any pics from you bro?:adore:
NO promises but i'll try to upload it soon :burnout:
fuh,
boxcarRacer, kereta kuat...
:burnout:
roll fender, please get it painted or else it will rust..
:bawling:
Good info as I'm looking forward to change sportrims for my Lite Neo...this will be my 1st mod before moving to the next stage.
Thats why i asking here. Just got my lite-neo early this year. now still waiting to fiinish the 3 so called free service (which actualy charging very high price on the parts and etc).
Baba, please take note that, if you change the rim if your car still under warranty, absorber, spring and also DISC BRAKE will void warranty.
There is still absorber problem in Neo, most of the car will have some noise on it which need to go back and re-tightening and so on.
Make sure u drive until satisfy (no mroe complain) only go do those void warranty things. (if your car still under warranty).
:itsme:
Haven't done nothing yet as my car is into 2nd free service [currently at 4.5k]. My ride need to check using PDT as the fuel consumption is on the high side...half tank can go 100-120km only. Seem that from full tank to half tank the needle move too fast and slowing down from half tank to empty.
As you said, need to solve all problem before start modding.
Me too going to 2nd service but i drive seldom so my car now only 3K km.
About the needle which do down fast then slow after half tank, mine too.
Don't worry about that as some of the car is like that depend on the tank shape i guess.
cuz my bro's waja (7-8 years car) also like that but the fuel consumption is ok.
My fuel consumption i think is ok cuz it's a 1.6 car.
You dont measure by half tank or full tank, measure by how much $$ or litre you pump in.
RM10 approximate can go 60km.
and oh please dont think it's rediculus about the fuel consumption like this,
cuz fyi my iswara 1.3ltr (10years old) also having RM10 to 60km.
unless this is your 1st car or u driving a small cc car previously,
or else u need to accept higher fuel consumptioin for 1.6ltr car.
u can switch you meter to see Approximate Fuel Consumption, which mine is showing 8.7.
if yours is higher then maybe some problem.
Other than what i told u the story on top, then u better go and check.:biggrin:
