anything to clean brake dust that stuck on the rim???
contreasjun27
9,000 RPM
subang
sifu sifu...
i got a big problem...i got a very heavy break dust brake pad..
so my rims will have the brake dust stain on it..
and it is super hard to remove..
and my rim colour is white...omg...so dam obvious and look dirty on the rims
Re: anything to clean break dust that stuck on the rim???
Firstly, what have you tried using to clean your rim?
There is some products special for cleaning rims that can effectively remove brake dust.
I used turtle rim cleaner for sometimes. Now i'm using meguiars wheel brightener (detailing series, very strong cleaner). both clean my rims well only left some road tar on it.
After you clean your rims, you can always top up wit a layer of wax (for OEM painted rims) to improve protections and ease to clean next time.
Some pics please.....
There are specific method to tackle specific circumstances. Firstly, need to know the type of finish is on your rims.
Try cleaning them with a strong car shampoo wash first. If that doesn't remove all then you'll need a dedicated wheel cleaner. If it's still there then you'll need an industrial strength cleaner (that's safe for whatever finish on your wheel). If that also doesn't work, chances are, the dust is stuck and you'll need to clay it off.
Waxing/sealing your wheel would be a good idea. It won't really prevent brake dust sticking to the wheels but it would surely make cleaning them a lot easier.
Regards.
oh i see i see...
i'm afraid that using those strong cleaner will eventually faded my paint though haha..
anyway i will try...then maybe top up a layer of wax as u say bro
Erm , using a toothbrush ?
I had been using SONAX Extreme Rim Cleaner and it had efficiently cleant all dirt and brake dust off my rims, including those stubborn dirt trapped in those bolt holes.
may i know where can i purchase this item???
and does it remove from like spray rims like 2k white color rims?
I bought it at Sunway Mentari, at the Sonax distributor at the row of shoplots after the Shell station.
This shop also performs car detailing-wash, polish, waxing etc, so I believe it is quite easy to locate.
will the wheel cleaner cracks the rubber?
my wheel is a 2 piece type. Lots of dirt, unable to clean in between the gap.
will the wheel cleaner help?
yo bro, i'm using that too... thanks to Sonax, now after i using it to clean the used wheels, customer seems to more happy to buy it....
This tool is worth considering to be used with your applicants
...errr...I use a baby bottle brush...cheap and effective....
hmm..onli sells at sunway?
is the sonax distributor sold at anywhere else such as accessories shop or etc?
contreasjun27,If u still have problem removing those stubborn brake dust from ur wheel after using Sonax,Meguiars etc,let me know,i have the perfect solution for u
cheapest and effective way I found is hot water and any kind of liquid detergent...i dishwashing liquid...try and see if it works for you bro?
