ok ok do not angry man. tonight i try to spin.
bro.. must engage gear first leh... coz i think when free gear lsd is not working one woh....
How bout gb lantai?any code stick on housing?thanks
hehehe... bro nothin wat brand u suggest for gear oil.
last night i tried to spin the wheel. the result is when free gear the other side wheel not spin. but when i engage the gear its spinning but reverse rotation.
consider its lsd or not?
From what I read about LSD, 2-way & 1.5 way you have to be careful in the wet/rain.
Because when you lift your foot from throttle, the two wheels still want to spin at the same speed. So if there is a big puddle of water on the left side of the road and dry road on right side, the LSD will try maintain same speed to both wheel, if not control, can cause spin.
1 way LSD is safest for FWD, but grip during cornering is lowest compare to 2 or 1.5 way LSD.
when you attack cornering,but first you had to have a good suspension set too la......
no need engage gear also can see the lsd work anot la bro...
if 2.0 means full lock, it will spin for both side all the way..
1.5 way means spin when u accelerate
1 way means spin when reach certain speed and certain condition...
that mean my gearbox got lsd lah but oem punye? what is relation between superstrut/twinpot with lsd? sorrylah friends banyak tanya. "malu bertanya sesat jalan"
what is different (performance) with the LSD brand? TRD, cusco, others
lsd will provide better handling of course, but it will also easily make ur both front tire spinning when u hardly accel....but normally when i am driving in very2 wet cond, or through a poll of water, the wheel spin from the lsd still pulling my car to the straight direction, i have never experinced the lsd will caused the pulling direction into the left or right like some of our brother mentioned/experienced before. maybe something wrong with me, my car not good, maybe i am driving too slow or maybe my lsd not good......maybe........
just my thought...if not agree oso okay....
Yes... compared to no LSD lo... Anyway, if base on info above... the OEM LSD is called 1 way LSD also ka?oem lsd oso good.
can you check the knuckle or ball joint? both of that also can cause this happen.hi all sifus n mmbrs of ZTH....I got several issues regarding this topic...hope U mind to share.
1. I could hear a knocking sound 'ktak' once, each time I drive my car out of junction (steering was fully steered to either left or right). does it indicate LSD or chasis crack? (hv changed driveshaft, yet still same)
2. LSD gb with normal/regular gb oil, will it cause damage to LSD gb?
FYI, just converted my LE to 20v bt...halfcut come with superstrut n twin port...
TQ all....
