- Joined
- Apr 12, 2005
- Messages
- 109
- Points
- 3,016
i've a big problem here...i'm using MIVEC RS engine...before dis i'm using standard exhaust (v6 exhaust) so i did't recognized wether the MIVEC is ON or NOT...before dat i'm using straight pipe till end..on dat time da MIVEC still can ON when reach 4800 or 5200..(i don't remember)..but now, after bout 6 month i'm using dat standard (V6 Exhaust),i change it to straight 2.2" pipe wif HKS muffler, i recogized dat MIVEC didn't ON anymore even da RPM reach to 8500-9500....i've try to detected da prob....i already change da distributor into 4g93..install new grounding cable..check ECU....check MIVEC head..check MIVEC solenoid n try it bypass...change to new engine oil..check timing wif timing light..but it only ON at 5500 to 5800 but not much power...da sound is like only valve for exhaust are open but not at intake valve...so it feel nothing if MIVEC ON..n i don't know wether it open or not when i test it on da road..so for da conlusion da MIVEC is still not ON much like before..so, if anyone have da same problem as me or ever face dis problem...plz help me n give me some suggestion to me to slove dis damn problem...it feel useless if i'm using dis engine w/out MIVEC...plzz help me guys..:cry_smile:
:sleep:
