Hehe... not too right... It's a 4G92 BOT...
oh really? It is BOT family also ar? hehehe..i think sure a lto of $$$ dumped for your project. Maybe it is time to get a real performer, 2.0 turbocharged 4G63 family le?hehehe
Bump:
nah, quite wrong if im nt mistaken
silvia's use T series turbo, not GT series, S14,S15 uses T28 turbos
all silvia's turbo use t25 flange type manifolds
T28's can whoop out 300hp and up to 370hp if its a FP T28 :P
GT2871 can whoop out more than 400hp at 1bar bt depends on your engines design , tuning and VE to be able to cope with that flow.
your GT28RS should whoop out max 300hp at 0.5bar
you may read the compressor map below yourself :) , at 1bar it will max out at 360hp , the GT2871 is about 100hp extra
http://www.turbobygarrett.com/turbobygarrett/images/catalog/Turbochargers/gt28_images/gt2860RS_739548_comp_e.gif
jinkl,
finally out with a compressor map hehehe...anyway this might be out of topic but i would like to ask your view on this.
Let's compare GT28RS vs turbo from evo1,2,3 be if TD05 16G or hybrided so calle TD05 20G.
i have made research, those TD05 16G and 20G have higher CFM compared to GT28RS. Of course GT28RS is good for better spool up time and i need earliest spool and high midrange power. but seems like disco potato it could hit high horse at much lower boost if compared to Mitsubishi TD. Why is that so? Is it due to the dual ball bearing design which decreases frition significantly that made it being able to push its rated max CFM at lower boost? i have seen real life and made comparison, TD series turbo need to be boosted really high to achieve similar CFM or HP, lets say average at around 1.3 to 1.5bar.
