FS : Performance Clutch Salve Pump for Evo1-3, 4G93T most early mitsu/proton gearbox
AlucarD
Hi There,
I'm parting with most of my performance stuff that I have collected. I have with me a Performance Clutch Slave pump for the Evo 1-3, 4G93T/P and most early mitsu/proton gearbox. This is the slave pump that is located at the gearbox that pushes the gear fork. The performance slave pump is sturdier and is most important if you are running an uprated or performance clutch system. This will last longer and relieves the stress of the master pump as well. So both pump last longer.
Thanks for looking
Re: FS : Performance Clutch Salve Pump for Evo1-3, 4G93T most early mitsu/proton gear
bro may I know wat r the differents between this and original evo3 pump?
both of them look exactly the same
Hi there, rakesh. This was bought from a reputable shop in OZ and I had a look after removing the rubber seal. The pump looks bigger and better build. Other than that, I would not know how the internals looks like until I disassemble a unit, but not gonna do that since this is brand new. I can of course provide invoice and receipts if you are interested.
hye bro...yes i am interested but i wonder how does this works coz im using e3 engin and my pump spoiled once,I replaced with e3 pump yet nothing happens....finally i replaced with wira 1.6 pump and it works better but i dont like it....so im doubting will this pump fixed the issue or will it be the same....just curious....
thanks bro
Lots of times modifying cars involves some RnD and a sometimes biting the bullet to try new things. Sorry it didnt work out for you but it could work for others.
what`s d best price bro
rakesh, check your PM. Thanks
--update--
hello, bro nak tny sikit, sory in malay. apa beza clutch pump evo std, dgn yang awk punya ni..??? apa kelebehan nya...?? boleh terang kan sikit.... sory bro...
No prob bro, tapi takut kena warning dari moderator. Ok, I cuba explain dengan BM. Clutch pump ni gua beli dari australia kira aftermarket performance type le tu. Mereka kate dah upgrade internal pump ni dan sepatutnya ia tahan lasak dari Ori. Kalau hang guna clutch laysing dan clutch pump selalu rosak atau rasa pedal tak syoik hang boleh cuba benda ni. Tapai gua belum lagi 'bedah' pump ni jadi tak tau internalnya kuat sebagaimana.
BM ok?
bm ok bro..... sorry late reply.... klu clutch pump i bocor lagi i call u....tq for your info bro....
pm me best price bro...
All gone
SOLD......
Thanks for the support
