- Joined
- Mar 14, 2009
- Messages
- 97
- Points
- 1,506
if any sifus here can tell me how to increase l2s top speed... my car still stock l2s only.. thanks...
what is ur rpm at 146kmh??top speed on road currently is around 146km... feel very slow.. i saw one member from zth can reach 170-180km.. how to achieve that speed??
when you reach 146km/h, do you feel like the engine losing power i.e... the push is lost somehow? if so, then the speed cut are not removesorry.. forgot to tell that my l2s is auto one... btw wat is speed cut??
I think you need to remove the speed cut first..easy if using apexi rsm, pivot speed meter etc.... some pomen oso tells me that you can remove the cut without gadgets mentioned by do some wiring to the ecu...top speed on road currently is around 146km... feel very slow.. i saw one member from zth can reach 170-180km.. how to achieve that speed??
got the gear ratio, tyre size and max rpm limit (see ur speedo)? I can calculate it via my GearCalc software....what is ur rpm at 146kmh??
dangerous la bro going at that speeds in a kancil ...
speak for ur self....ur car's a speed demon
....err r u the same syeni as in kcarlife? :hmmmm:
... and when it was stock i removed the speed cut using RSM and increase the boost by 0.9 using gud ol "tulang ikan"...
can say so... coz if at 146kmh, tacho already at 6k rpm (assuming no clutch slip), means ur top speed is limited to gear ratio...got the gear ratio, tyre size and max rpm limit (see ur speedo)? I can calculate it via my GearCalc software....
MAYBE ... kekekekeke :wavey: ... it doesnt hurt giving advice
Well here's my opinion ... 180kmh is possible with an auto L2 ... my car started life as a normal L2 auto untill i met some friends that are otak 3 suku... and when it was stock i removed the speed cut using RSM and increase the boost by 0.9 using gud ol "tulang ikan"...
clocked my RSM 18+ kmh ... but thats electronic ... i dun think its faulty ... but then i might be wrong ...
anyways drive safely ...
ur car is auto tranny rite??... how long since u first changed ur ATF??i dunno abt the gear ratio... if not mistaken the RPM for 146km is around 5500.. my car rims is 165/60/r13..
so no choice but to raised it abit...
