that mean minimum is rm8k for complete basic tunning?
Btw, I love campro with turbocharged![]()
thanks for the explaination... woah , ur last sentence make me scared to BOT la bro...
btw, does jpj allow this BOT modification? if do BOT then got roadblock.. what will happen?![]()
agreed.....the engine number still the same as factory fitted.....No... u don't need to re-register the engine back... since u use the same engine...
To be frank 1.3 campro engine not suit to BOT. Dangerous level still there even you got everything right. My advice is get 1.6 stroker kit first and then BOT after that. No point to take risk.
Another option is replace current 1.3 piston with 1.6 piston . !.6 piston can lower the compression.
hoaaaa.. 1.6 stroker kit? how much does it costs? whats the function of it? i'm new with this engine thing...
can u explain why u said 1.3 campro not suit to BOT? i really appreciate for your explaination.
p/s: thanks. :wavey:
what wirajadian said is right . 1.6 liter stroker cost moe than 2k if you manage to find those used. Stroker kit is hardware to increase or reduce displacement of an engine for same same engine block. Piston , connecting rod and crankshaft are parts of stroker kit.
If this campro engine boom.. then where to find another campro engine?? Chop shop sure dont have.
Bump: If this campro engine boom.. then where to find another campro engine?? Chop shop sure dont have.
err... sounds like my 1.3 engine will producing the same power as 1.6 engine after installing this stroker? like that aa? if want to buy *new* , anyone here know?
p/s: looking for engine 101...![]()
yup... ur engine will produce the same amount of power as 1.6 Campro... buy new r? hmmmm... then Proton or spare part shop will be ur answer... then i think it will cost u a lot... i think...
Mrafif .. If you want campro 1.6 engine. Let me know , i got 2 campro engine sitting at workshop. Just sold one. Left one . both just run 20k - 30k. Owner switched to GSR and AE111
You are kidding with me Mrafif
Any idea on the fuel consumption?
