DC5 Advice
weiii passing Putrajaya summore ... didn't call me ... i'm very near u know :P
hahf ... ur car witout management kaw kaw already ... seen u in action on last trackday ...
with management waalaaweeiii ... monster status for sure!!! :driver:
Bump: weiii passing Putrajaya summore ... didn't call me ... i'm very near u know :P
:rofl: so...i terpesong from original plan...it increases 20ps and 3kgfm, still less than taikor jerry and jonet.
i think i know why.....its your Js Airbox.... you should get like mine, the air flow is very very good....if you want i sell it to you...:biggrin::biggrin::biggrin::biggrin::biggrin::biggrin::biggrin::biggrin:
:thefinger: *need to hide the car*
my immobilizer light now keeps flashing...need to go back Jacky there ask him pull out the ignition wire is it? :confused:
i just realise front passenger side, carpet is wet, with water dripping out from underneath the glovebox. is it aircond water? anyone else has this problem? :banghead:
my car ........ all the carpets are wet , and i dont know why :confused::confused::confused::confused:
Bump: my car ........ all the carpets are wet , and i dont know why :confused::confused::confused::confused:
last night saw about 10 DC5 wnet to R&R seri kembangan
got TT last night?
today service car.
Change clutch fluid, engine oil and gearbox oil after hcoc track day.
dyno is on this weekend most likely.
kpro? haha i wish i got the money printing machine from bank negara :biggrin:
hahf,
sorry for the newbie question
lately, my clutch pedal produced squeeking sound every time it was pressed. do you reckon by changing this clutch fluid it will make the noise go away?
how much it cost u to change the clutch fluid?
hahf,
bro u might wanna try dis DIY thingy first...it might help
hahf,
hi farhan,
refer to meor for the sound.
most likely it comes from the pedal and hose, just like meor's case.
it cost half a bottle of brake fluid (dot 4 or above).
prasath: I wish i could even have the opportunity to be naughty lately :rolleyes:
unfortunately , with ridiculously stiff suspensions and even stiffer engine mounts ......... no women wants to get jiggy in the car with me! :banghead:
Bump: prasath: I wish i could even have the opportunity to be naughty lately :rolleyes:
my clutch also got sounds. more of click-click-squeak everytime press n release. must be metal movements on the pedal. gonna experiment with wd40...
u guys use dot3 or dot4 for clutch n brake fluids?
recommended strictly dot 4 ..........
dot 5.1 also ok from what i hear :biggrin:
Bump: recommended strictly dot 4 ..........
There was a period of time a few months back my clutch had a clicking sound.
It first started with 1 click, then click-click, then so many clicks, until it became really annoying. The click is like the sound of winding up the coil of a kid's toy car.
So I tried spraying whatever moving parts at the clutch pedal with WD-40. It's really really painful because u have to literally stick your head under the steering column, and that also u can hardly reach it with the WD-40 red tube. Had to aim and spray from far. And after all that shit, in the end the noise still there!
Went to a couple of mechanics, they also tried the same thing. No amount of oiling worked.
Then the last mechanic told me to come another day in the morning, he will open up everything and check, suspecting a spring or something broke. Days went pass as I couldn't find the time to send my car in, and days because weeks, and all of the sudden, the noise stopped and never came back til today!
I don't know what's wrong or what fixed it, but i'm just glad the noise went away and pray it doesn't ever come back.
my car also have a same soung crick crick...at the 1st i think is my clucth bearing sound..but after i check...is the cover sound ..no my clucth...is the drive shalf cover sound..clivk clic went u push the pedal..the sound gone u release the pedal.the sound com back click click again...
try to check the drive shalf cover......i think we got a same problem..hopefully this can help..cheers..:burnout:
Thanks bro for the info.
However, mine is the opposite, i forgot to mention.
My click happens during pedal release. When pushing no sound, weird.....
no died...:driver: still alive..:rolleyes:
Bump: no died...:driver: still alive..:rolleyes:
