Cheap EVO 4> stuffs
Cheap EVO 4> stuffs
Synon'G
Cheap EVO 45678 stuffs
I've some abandon project parts for sale.... its going cheap...
a) 1set of Pauter Rods (x beam) for EVO 2.0 - 2.4 RM3000 Brand New!!!
b) 1set WESICO Performance piston (full skirt) for EVO 2.0 RM1900 Brand New!!!
c) 1pc COMETIC Performance Gasket (bore 87mm) for EVO 4> RM380 Brand New!!!
d) 1pc SUPER90 Throttle Body 70mm for Honda B,H,K series RM550 Brand New!!!
e) 1set SUPERTECH performance valve spring (complete set) RM1900 Brand New!!!
f) 1pair HKS 272 performance cam shaft for EVO 4> RM2200 Brand New!!!
g) 1set Hi-Performance SOLID lifter for EVO RM1500 Brand New!!!
h) 1set ARP head and main studs for EVO RM700 Brand New!!!
I) 1set KINGS performance con-rod bearings for EVO RM250 Brand New!!!
j) 1unit Microtech LT-10s (3months old) for EVO 4> RM2500 Used!!!
k) 1unit Microtech X4 RM450 Brand New!!!
l) 1unit Turbosmart performance wastegate (38mm) RM900 Brand New!!!
m) EVO 5 engine bored to 87mm (without pistons and con-rods) RM2800 Used!!!
Please contact me at 012-4331100
wat is the function Microtech X4 actually??? does it fit for evo 6??? how much actually???
It works on MICROTECH STANDALONE ECU(others stand alone ECU i'm not sure), can be fitted on any car or model as long as you have the STANDALONE ECU to work with... And a set of individual coil is required for this application! I bought RM550(some selling at RM600) and now i'm asking for RM450!!! thanks!
Bro microtech lt 10 can use at my mivec turbo not?
If can pm me best price and where to install & tunning?
Bro, My MICROTECH is for EVO 4 and above... Mivec, 1.8, vr4 and EVO 3< are using another base map! thanks...
Bump: bumpsss.........
let go let go letgo letgo..... thanks!
