wait,this is my ar50 pic..
so what your commnt?
back(bontot) turbo ar63..
i buy at tong turbo..
its not ball bearing trbo..
but when i buy it,die tulis kt banana T3/T4..
Bump: so now yg byk kuarkn hrsepower bontot or dpn?
Jin being Jin...
The SIFU SPEAKS LIKE A SIFU....
wei , SDF is the sifu , im the "COPY INFO FROM NET" guy
picture also copy from SDF la
i believe there's many sifu , u juz dono who they r....
most common one that tong sells is the
57trim T04E T3/T4
56mm inducer , 76mm exducer
not that laggy on a 2.0 , should bring u to the 400hp range
yala.. that is t3/t4 la
the compressor size is around 56mm/76mm
turbine is something like stage I size la... if mm i agak agak around exducer 50mm/62mm inducer
i forget izzit 50mm or what.. but im sure is 62mm inducer of turbine wheel size kekekeke..
he suggest for GSR with banana :)
hp setup i not sure la...
next month going to buy one something like this to BOT my ride kekekeke![]()
! who can help me!!!!!!!!!!!!!!!!!!!!!!!!where the workshop can help me repair!!!!!!!!!!!!!!!!!!!!!!
