is the dogbox same with straight cut gearbox?:hmmmm:
nope... havent got a change to experience it before...Sky...have you seen one and experienced it? I havent had the chance...must be really nice...![]()
http://www.youtube.com/watch?v=i6ce...g-k20a-300hp-279.html&feature=player_embeddedreally?maybe u can show us the video or sumthing..sound nice..hihi..![]()
not same... dog engagement gearbox doesnt require u to use the clutch to shift gears... gears interlock with each other at an instant... straight cut gearbox can be either dogbox or normal clutched gearbox....is the dogbox same with straight cut gearbox?:hmmmm:
go and try for urself lois that true what i heard, my friend said, powerzone short shift very good n smooth to engage gearing???
what i can comment is dat... it is more of a syokshifter den a shortshifter...But is it really true its more fun with it? Or cumbersome...
Does the brand make a difference in terms of the smoothness?
Comments and thoughts guys cause I may well get one this weekend.
syok la... belum try belum tau... sudah try hari hari mau...yeah...still not sure if I should try it...if dont like...jialat..kena take out again...
Sky, really syok ka?
yea diy easy niainstalling a quick/short shifter in an Iswara is not at all difficult and often it can be DIYed.
when you are driving with quick shifter it does feel sportier and a pleasure to drive around shifting gears. provided you purchased a decent quick shifter and installation is done right. Price is MYR120.00 per unit if you want it.. not expensive at all right? i've done on many Iswara/Saga and so far all are quite satisfied with the result.
yeap can fit back everything nicely... i'm still using the original gear cover boot and original gear knob.... no problem... looks fairly stock standard...Nice...So Sky the gear cover can fit back nicely yes?...Thanks for the pics man.
http://www.zerotohundred.com/newforums/car-modification/276044-dog-box-dog-engagement-gear-box.htmli like my short shifter. its hard and short, thats what i really want to feel when changing gear.
when it's firm, u feel good. of course the extra energy u need because of the short lever. but i'm thinking of modding it to extend the gear lever a bit higher.
sky: what is dogbox? sequential gear? where to find?
