"All Toyota Guyssssssss.That's what u wan to see. last 3 weeks my engine already run the best time ealy 9sc at Eastern Creak Australia Drag Way.Somebody unbelieve the 1.6L engine can run 9sc with BIG Hp!!!!!!....Yes we done it.This is spec of my engine.1.20V head2.Oversize 1mm Valve3.Performance Valve spring4.Port and porting head 5.Cometic head gasket6.ARP head Gasket7.RPM 288 cams8.Oem Cam pulley9.Wiseco 81.5mm CR 8.0 pistons10.PAR Rod11.ACL Bearing12.Stage 2 dry sum pump13.Electrical water pump14.Mechanical Fuel pum Stage 2 15.8 x 1600cc injectors16.Bosck coils17.Microtech LT10s x4 box18.Turbo T6619.Turbosmart Eboost20.75mm throttle Body21.5bar xternal map sensorHorse Power 640whpM3 VP MethanolStarlet FWD BodyLow boost 25psiHight Boost 45psi2nd Drag race 2008 at Sepang my toyota DX Rwd already get the 1st podium Catogory D 1.6 N/A Below Standart Body with 6 point Rollcage.To see the engine pls click http://rpm2racing.fotopages.com/?entry=1569600&back=http://rpm2racing.fotopages.com/?page=0ThanksRPM2 Racing Malaysiahttp://rpm2racing.fotopages.com"
apparently the topic started with a claim that the engine "was" built and even ran to a podium finish in Sepang... a couple of months later...the topic starter has now made 180 turn to say it wasn't his build...
smells like fish........... :slug:
