WTA: Dont have honk after conv. to bt
corollagl
Hi Guys..n all sifos
My car Se limited dont have Honk after conv. to BT engine(Ae111).
My mechanic suggest to put ae101 streng honk switch n wiring.
Any guyz n sifos got experience in this please advise me.
As I know Ae101 n Ae111 is different in honk wiring. Also the material of wire also different.
Help me please..my car dont have HONK...
:banghead::banghead:
what ur honk mean??? Horn isn't it?
Well... you may pull the new wiring just for the horn only ma... Take it to your nearest wiring shop, it should not be big problem.
err...beside tat try to check ur booskit too...got the wiring black n red color under ur horn button...;D
p.s welcome to toyota mod world...hmm
Yeah.. frez, better go to wiring shop.
just spent little rm only..
sometimes my IQ low..hopefully not always..
juz tie this besides your sidemirror...
http://www.made-in-china.com/image/2f0j00WCtTvijcHgqVM/Metal-Straight-Horn-SNH002-.jpg
1st time i heard full conversion got horn problem...eqeqeqeq...
all can can be used...no need to mix n match to much...
unless...your horn pin (which got a spring on it, if you fully dismantle the steering wheel)...is faulty or not connected...
where's your location ?
are you willing to travel to Bandar Teknologi Kajang ?
to see a "Leng Chai" toyota mech sifoo... :smokin: :biggrin:
are you using ori dashboard or the bt dash?
coz steering column n steering is different, bt is using airbag type, which is using spinner for both airbag n steering horn, while ae92 is non airbag type which uses copper contact point for horn...
I'm using Bt dashboard.
What you says same with my mechanic told.
Bt using spinner.
meanwhile I'm plug momo stereng.
How to connect momo horn wiring to spinner(like ribbon wire)
Bump: Guyz
My d.board got panel to plug player@lcd.
who can explain from which model this bt?
rare got like this.
Bump: Guyz
rare got like this.
u r using ae111 4 door dash, very nice looking coz got double din head unit scope.. f u can find the ori japan boss kit from h/c shop that is nor airbag, then solve ur problem already... not big deal lar.. since u r using the bt dash n the steering column..
sorry ya typing error, what i mean is to get a boss kit from halfcut that is for airbag type, then will solve your problem already..
So I need to find boss kit for airbeg sterenglah?
Can use any brand or boss kit 4 toyota only?
