My ceFIRO
vvel engine is to replace VQ engine
http://img.worldcarfans.com/2007/3/large/2070329.003.Mini6L.jpg
http://img.worldcarfans.com/2007/3/large/2070329.003.Mini7L.jpg
http://img.worldcarfans.com/2007/3/large/2070329.003.Mini3L.jpg
Nissan Motor Co., Ltd. introduced a new engine technology that delivers a balance of responsiveness and power, fuel efficiency and low emissions. The new system combines the technologies behind Nissan's newly developed Variable Valve Event and Lift (VVEL)*1 and continuous valve timing control (C-VTC) to deliver significantly enhanced performance. This advanced technology will be available to customers worldwide through the Nissan and Infiniti product lines. Nissan announced plans to install the VVEL system, which contributes up to a 10%*2 reduction in carbon-dioxide emissions, on its products worldwide starting from FY07 under the Nissan Green Program 2010. The first product to feature the VVEL technology is the Infiniti G37 coupe, scheduled to be unveiled at the upcoming New York International Auto Show in April, 2007. While conventional engines control air intake using a throttle valve, VVEL-equipped engines do this directly at the intake valves, continuously controlling their valve events and lifts. C-VTC and VVEL together control the valve phases and its valve events and lifts, allowing free-control of the valve timing and lift. This results in more efficient airflow through the cylinder and significantly improves responsiveness, optimizing the balance between power and environmental performance. The new engine offers the following advantages depending on driving range: Higher fuel efficiency
•At low-to-mid load ranges, the system controls air intake at the intake-valve, immediately before it enters the combustion chamber, in contrast with conventional engine air intake via a throttle valve, leading to increased efficiency by easing airflow through the cylinder.
•In the low- and medium-rpm ranges*3, intake-valve lift is kept low to reduce camshaft friction and improve fuel efficiency.
Better response
•Controlling air intake at the intake-valves improves acceleration response by allowing more dense air into the cylinders from the start of acceleration.
More power
•In the low-rpm range, the intake-valves open for a shorter period, preventing blowback of the air-fuel mixture and improving torque.
•In the high range, greater intake-valve lift allows increased air intake to deliver greater torque outputs.
Cleaner emissions
•Intake-valve timing is optimized on startup, when the engine is still cool, to quickly raise the temperature of exhaust gases and more quickly activate the catalytic converter.
•Hydro-carbon emissions are reduced in the low-to-medium range by keeping intake-valve lift low, speeding intake flow and dispersing the fuel into a finer mist, resulting in more efficient full combustion.
The VVEL improves fuel efficiency most effectively in the low-to-medium operating range, thus it is best matched to the multiple-cylinder and higher displacement engines, that typically operate within that range. Under the Nissan Green Program 2010, Nissan has announced plans to develop gasoline-powered engines with CO2 emissions reduced to levels comparable with diesel engines, to be available globally by 2010. For multiple-cylinder, high-displacement engines, Nissan will combine VVEL technology with the direct-injection system. The VVEL system A rocker arm and two types of links close the intake-valves by transferring the rotational movement of a drive shaft with an eccentric cam to the output cam. The movement of the output cam can be varied by rotating the control shaft within the DC motor and changing the fulcrums of the links. This makes a continuous adjustment of the valve lift amount possible.
Source: Source: Nissan Motor Corporation
http://www.nissan.co.jp/CEFIRO_W/A32/9908/EXTERIOR/IMAGE/03_b.jpg
http://www.nissan.co.jp/CEFIRO_W/A32/9908/EXTERIOR/IMAGE/02_b.jpg
http://www.nissan.co.jp/CEFIRO_W/A32/9908/EXTERIOR/IMAGE/01_b.jpg
http://www.nissan.co.jp/CEFIRO_W/A32/9908/INTERIOR/IMAGE/interior1_a.jpg
V型6気筒を基本に、エンジン本体にアルミ合金などの軽量素材を数多く採用。 剛性を高めるとともに、軽量・コンパクト化を図った高性能エンジンです。 同時に主要運動部のフリクション低減等により、低燃費と高性能を両立。軽いアクセルワークで 素早く応答するレスポンス性能と実用域での高いパフォーマンスが ドライバーに気持ちのよい走りをもたらします。
http://www.nissan.co.jp/ELEMENTS/MECHANISM/IMAGE/cefiro_w9908_eng1.jpg
VQ25DE
●総排気量 2495cc
●最高出力 190PS / 6400rpm
●最大トルク24.0kg・m / 4000rpm
●燃料消費率(10・15モード)9.8km /l
http://www.nissan.co.jp/ELEMENTS/MECHANISM/IMAGE/cefiro_w9908_eng3.gif
http://www.nissan.co.jp/ELEMENTS/MECHANISM/IMAGE/cefiro_w9908_eng2.jpg
VQ20DE
●総排気量 1995cc
●最高出力 155PS / 6400rpm
●最大トルク19.0kg・m / 4400rpm
●燃料消費率(10・15モード)10.2km /l
http://www.nissan.co.jp/ELEMENTS/MECHANISM/IMAGE/cefiro_w9908_eng4.gif
http://www.nissan.co.jp/CEFIRO_W/A32/9908/SPECIAL/IMAGE/01.jpg http://www.nissan.co.jp/CEFIRO_W/A32/9908/SPECIAL/IMAGE/02.jpg
Rare lamp n grill
Better response
More power
Cleaner emissions
This looks like RWD engine leh..
---------- Post added at 03:56 PM ---------- Previous post was at 03:55 PM ----------
VQ25DE
●総排気量 2495cc
VQ20DE
●総排気量 1995cc
Rare lamp n grill
Planning to get a wagon?
dash board nice wor
2.5L 1/2 cut is like this..
but normally cond not so good coz long time expose to sun, rain, smoke...
so aircond control by second portion, look like 2din player?? right.
very special indeed.
---------- Post added at 01:18 PM ---------- Previous post was at 01:14 PM ----------
swap engine only... gearbox use back :D
can change boot to wagon style? :D
abang masuk 3.7 vvel engine, lagi syok if the price are not much different.
---------- Post added at 01:26 PM ---------- Previous post was at 01:18 PM ----------
then can drift liao :rofl::rofl::rofl:
need some advice on grill colour, middle emblem will be replace by nissan new emblem..
pattern 1
http://img35.imageshack.us/img35/9544/slide1eyr.jpg
pattern 2
http://img90.imageshack.us/img90/2225/slide2j.jpg
pattern 3
http://img232.imageshack.us/img232/392/slide3u.jpg
pattern 4
http://img233.imageshack.us/img233/8272/slide4p.jpg
which one looks better?
http://img242.imageshack.us/img242/8433/missing.jpg
this area should be hv something screw there?
pattern 1
pattern 2
pattern 3
pattern 4
Actually that is a piece of a/c hose, that area as you have mentioned is for the a/c man to check ur a/c pressure or fill a/c gas i think. It should have a cover something like your tire valve cover. u can be creative and replace a chrome cover over it , hehehe...
cannot imagine..:banghead: haha..
can snap pic of urs
seizai,
Get the cover from any A/C service center. They should have it. Is very standard size. I think most mechanic shop also have it. Is better to get it closed / cover
here they are.
sorry for lousy pic, snap by lousy phone camera.
