...maybe we can try mix RON95 with RON 97 and see if there is any knock..I'll try on my SVT soon...full RON95 and Mix 95 with 97
Just tested RON95... got knocking a bit especially during stop-go situation in 1st or 2nd gear gear. Also knocking more noticeable when VVT kicks in. Power wise cant feel any difference yet, perhaps someone should dyno compare between 97 vs 95. FC don't know yet but more or less should be the same. Will update on this as well.
However, its recommended to have higher fuel press when running RON95 on 20V engine or octane booster.
Enlighten us on this.
The price of fuel is killing me, are there any ill effects of mixing our petrol? (i.e. using 95&97 at the same time, mixing basically.)
I think if mix ron95 with ron97 shouldn't be an issue, but you will create something new called ron96.![]()
If you talk about math, then u need to bring it to the science lab and do proper testing. But logically, I dont think there will be any issue mixing both RONs. The first moment you pour RON95 into your tank, you are already mixing it with RON97 (assuming you were using RON97 previously), unless you drain out your fuel tank and fill it up with RON95 only, which is very unlikely.I wonder if the maths is that exact:hmmmm:. I'm terrible at math. If mixing them would eliminate or reduce the pinging, that would be great.
Bro cybtech, As for adding crushed mothballs into the tank, I think better not to do this as it might clog the fuel system including the injectors as well. IIRC, mothballs was tested by Mythbusters and they did claim that the engine responded better. I think Toluene should be a better choice to bump up the RON rating. Pls read the earlier link where I posted about the DIY octane booster.
