Im currently driving a civic ek4 with ek9 tranny and thinking of changing to b18cr engine kosong. Anybody done this conversion before? I wanna know wat parts can use back from my ek4 si.
if the Extractor r usning for B16A, sure cannot use back...
Icic. Is the b16a injector and fuelrail same as b18cr?
fuel rail same, but not sure bout the injector...
as ur b16a head still retain, so... try to pay attention when dyno tuned... if the fuel can't match the powerband, then only change the injector la...
No, im planning to change whole engine to b18cr with b18cr intake manifold but may use back the fuel rail and injector if its same. Can i use back my ek4 wiring, distributor and ecu?
cannot bro... if u plan to get a whole B18CR, why still bothered the b16a things..??
if u get the full engine, wit intake, sure u'll get the fuel rail & injector ma..
yup, u can use back the EK4 wiring but need some little relocate...
ur distributor cannot use back... but ecu can... but need the piggyback or Crome it..![]()
Ur right maybe i should 1 time find full engine just without gearbox...normally how much will b18cr full engine cost?
Does a B16B gearbox fit a B18C?
rm6-8k... depends on the condition & wat it got...
This price including the gearbox ?
Very cheap lor if this price.
Complete gb with pedal,gear lever,etc...
also 3k edy...
u mean b16b gb ar...??
only the 4.7 gb oredy cost u more than rm3k...![]()
Yep..
4.7 ofcoz mor expensive laa...![]()
Normally there are 2 source of leaking from them. The rubber surrounding the door loose or damage liao OR most likely the water proof plastic sheet inside the door got holes or not...
